Question about RCA HD52W59 HDTV Projection Television
The image on my hd52w67 looks like its in 3D - RCA HD52W59 HDTV Projection Television
  • cierra_39 Jul 01, 2009
    what is a ic
    President:
  • 788 Answers
Your symptoms sounds like a damaged convergence IC’s.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
Most of the time you can just correct the convergence through the television menu. All that needs to be done is line up the blue and red to the green. If the colors do not move then there may be faulty components in the convergence circuit.
You may want to consult a Television Repair Technician, or repair this yourself. If you want to tackle this yourself, let me know, I can give you some direction for the repair
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jul 01, 2009
Why does my projector display a double image?
You may have turned on a 3D (side by side) mode.
Have a look at your remote, press the 3D button (you may have to press it several times) to cycle through the virtual 3D modes.
Once you see "3D off", the double image should go away.
If you want to use 3D again, simply cycle through the modes to go back to where you want to be.
Jul 25, 2014 | Sony VPL-HW30AES 3D 1080p Home Theater...
My RCS HD52W67 is showing three pictures on the screen. I have tried zooming, but it only makes all three pictures larger. I cannot get it to only show one screen. What can I do?
Your TV most likely has a convergence failure. You can get parts and instructions from www.tvrepairkits.com Here are some of the most common symptoms and example photos of a convergence problem Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
Nov 22, 2012 | RCA HD52W59 HDTV Projection Television
My 47 inch vizio 3dtv has issues with the 3d. There are two images and neither are in 3d. The glasses don't work.
You have to put the TV into 3D mode to view it by pressing the 3D button on the remote. Before you press that button, look at the screen... if you see two images side by side, then you would choose SBS... if the images are one on top of the other, then it is the over/under mode, or with Vizio,Top/Bottom option which is the "TB" icon. Once you have chosen this, the screen will inform you to put on your 3D Glasses.
Aug 15, 2012 | Televison & Video
I have a 52" rca hdtv. the screen looks like its in 3d. can this be fixed? model# hd52w67
It seem like a convergence trouble. I tink it is a ITC222 chassis in this set. If it is, you probleme is eeprom for convergence need to be reprogrammed and cause no power on convergence board.
Apr 22, 2010 | RCA R52WM24 52" HDTV Projection Television
Have the HD52w67 rca. Have a 3d effect. know we have to adjust the lamps. we go to menu but we have no auto convergence. What can we do now?
Is there a manual convergence setting in the menu? if so try to adjust the level 1, 2, and 3 settings. If not try to clean the lenses with qtips and alchohol.
Mar 07, 2010 | RCA HD52W59 HDTV Projection Television
I have a rca hd52w67 projection tv and the screen looks like it is concaved,has three lines across the top and looks like it is in 3d. What is wrong with it?
The convergnce amplifiers have failed.
This is a common old-age problem.
This requires replacing the convergence amplifiers and possibly resistors and fuses. A repair shop would charge $300-$400 to repair.
If you are tech savy or know someone who is, thae parts will cost around $40.00. Search this site for specific instructions.
Good Day,
-Dan
Sep 10, 2009 | RCA HD52W59 HDTV Projection Television
Tv looks like it is in 3D
Sounds like your convergence amp board has gone out and will need replaced. If you feel like giving it a try yourself this web site has them fairly cheap and they have an 800 line if you need help determining your board number.
http://www.moduslinkptstvboards.com/Default.aspx
Aug 13, 2009 | RCA HD52W59 HDTV Projection Television
3d pictures on hdtv hd52w67
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jun 07, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W67 convergence menu missing from menu and has a b,r,g line going through the top of the menu and it looks like every thing is in 3d
that model doesnt use the two STK ICs that most other models use. Try replaceing fusw fl231 . The schematics arent easially available for any RCA TVs unless they are the older projection ones. I would recommend checking with this link and seeing if they have the service manual or perhaps they can get it, if you leave an email with your model number.
http://servicemanuals.vstore.ca/
Jun 06, 2008 | RCA HD52W59 HDTV Projection Television
Problem with uploading Map Update 2008
"Isn't it supposed to look like the image on the package? "
NO, the image on the package is just for show. The newer Garmin C5XX, Nuvi, will allow you to change to a car icon. To get 3D go to the main menu and select the wrench, then select map, then Map view to change to 3D.
Mapsource 2008 only upgrade the streets and POI (point of interest).
Jan 12, 2008 | Garmin StreetPilot C330 GPS Receiver
RCA HD52W59 HDTV Projection Television Logo
261 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
