Question about Vizio L32 32 in. LCD HDTV
The power went off a couple nights ago now my vizio 32 inch plasma tv wont turn on at all nothing this happened one other time and someone else held down the power button after 3 days and it finally turned back on. Now its been 4 days and we cant get it to turn on at all it is about a year old! any suggestions???
    President:
  • 1,077 Answers
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jul 01, 2009
I have a 32" vizio plasma that wont turn on
hello,
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where.If otherwise, Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem......
Jul 06, 2011 | Vizio VP322 32 in. Plasma TV
I CANNOT TURN TELEVISION ON
You may have failing power supply module.
http://s807.photobucket.com/albums/yy352/budm/VIZIO%20L32HDTV10A/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 29, 2010 | Vizio L32 32 in. LCD HDTV
My vp322 visio will not power on
Power supply in your TV went from bad to dead. You can remove rear cover and try to locate bad capacitors (they will have bulged tops instead of flat ones). Replace them and see if it's going to resurrect TV. If not - whole Power Supply board have to be replaced.
Regards.
Russ.
Apr 04, 2010 | Vizio VP322 32 in. Plasma TV
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Jan 05, 2010 | Vizio L32 32 in. LCD HDTV
My Vizio just shut off and lost power it a 50 inch and dont understand why?I didnt plug anything in to it so why does this happen it wont turn back on Todd P.A.
This same thing happened in my 32 in vizio and vizio paid an HDTV tech to come out to my house to fix it. He says he ALWAYS gets calls on vizios and this same thing is always the problem. He said Vizio paid more money for the screws on the tv then they did the power board in the tv. You want to either have someone fix it or buy a new power board and fix it yourself. It took the tech 15 min from start to finish to fix my tv and he had drove 2 hours to get here.
Oct 02, 2009 | Vizio 42 in. LCD TV
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Vizio, Model P4, manufactured in 2003 -- worked fine until 5 minutes ago
I have the same tv and the same problem. The power switch in the front flashes a bunch of times, but nothing else happens. Have you had any success in getting yours fixed?
Sep 08, 2008 | V, Inc. Vizio P4 Plasma Television
Television will not turn on
My 47" Vizio wouldnt turn on this morning.....had a similair problem 3 yrs ago.....this is what i did and fixed the problem myself.....apparently you have to reset TV. Here is what has worked for me. So unplug tv power cord from the tv. Hold the power button and imput button together ( located on side panel ) for approx 45 sec......plug cord back into tv. Press power button on tv and voila !!!!! Tv came back on!!! I have had my Vizio almost 5 yrs. But have to call the unhelpful customer service atleast once a year.... I hope this works for you :)
May 03, 2007 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
291 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
