Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
Yellowing picture i have owned my tv for about 5 years and have replaced the lamp twice and the light engine once under warranty now it has a yeloow tint that covers 90% of the screen the only part that looks ok is the outer edge. any suggestions or similar problems?
  • 30 Answers
Its a light enine again, excessive heat from lamp causes this, either getting dust in fans or ducts around engine,
Posted on Aug 09, 2009
I have a Panasonic 60 inch TV, which I just changed the bulb less then two months ago. I called the bulb distributor and they said send back the bulb for tests. My problem is that I am not sure if it is...
i believe that the lamps on this model are warrantied for 5 years and labor for 3 years from panasonic i suggest calling panasonic for advice on where to go further.
Dec 23, 2010 | Panasonic PT-61LCZ70 Television
I have a Mitsubishi diamond WD-62725 the lamp light was on so i ordered a new replacement for it I installed the new lamp and the picture looks brighter than ever remember seeing it but the lamp light is...
we have the same brand tv but the 65" model. had a 4 year warranty just in case the lamps went out. the lamp went out and we called conn's to come out and fix the tv. the repairman replaced the lamp, and then he said to unplug the tv from the wall or the strip it is plugged into and wait 5 minutes and then plug it back in. he left and said to call him back if that did not work. did what he said and it fixed the problem. try unplugging the tv for 5 minutes and plug it back in and see if that might take care of your problem.
Jun 22, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Tv has no picture or sound. replaced bulb no help greenlight blinks 79 times. red lights start blinking
Lamp light flashing once every 5 seconds or twice every 5? Twice every 5 seconds,....lamp failure, once every 5 seconds,...ballast or thermal fuse failure. You have a lamp, ballast or thermal fuse problem. The ballasts are a discontinued part and can only be purchased used at approx. $225.00 or rebuilt for around $175.00 less any service charges to diagnois and repair.
Jan 17, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Tint is yellow green
bad light engine call sony and see if your tv is one on the extended warranty list.
Sep 20, 2009 | Sony KDSR50XBR1 50" Projection HDTV
Panasonic projection tv model # pt56lcz7 no picture, bulb out?
This unit does not have the usual lamp assembly that most do. On this unit the whole light engine has to be removed to replace the lamp assembly. Part number is LFS4000PA1 and cost is $1,351.95 @ www.partstore.com.
Sep 01, 2009 | Panasonic PT-50LCZ70 50" HDTV
Yellow coloring on Panasonic TV
IN THE MENU FIND COLOR CONVERGENCE TO FIX THAT
Nov 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-56LCZ70...according to the manual it's "malfunction 9"...lamp light blinking red twice.
Just curious when all of you purchased tv's. We purchased ours in Jan. 2008. and is now having the malfunction 9. Online manuel says this is a lamp problem and lamps have a two year labor 5 year part warranty so I am working on getting it taken care of under warranty as I have heard lamps are pretty spendy. I will try to let you know how it turns out....Any updates on yours???
Jun 30, 2008 | Panasonic Televison & Video
50vx500
The lamps can do many odd things when they are on the way out includung the picture coming on and then dissapearing for a while then coming back. The lamps adverage life is 2000 hours, and at 3-5 years it is on borrowed time.
May 13, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
My set switches from low lamp to bright lamp on its own constantly
I just got mine back from the shop withe a similar issue. The picture would dim especially with dark scenes and you could actually hear the lamp popping and clicking. It was not consistent enough that I had to video tape the issue for the technicians. In short, they decided that the ballast was faulty, unfortunately, the only way to replace the ballast is to replace the entire light engine. The part is about $320 and they also replaced the lamp for $150. The extended warranty would have only covered parts I believe so you may have ended up OK.
Jul 12, 2007 | Toshiba 72HM195 72" HDTV
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
206 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
