Question about RIM BlackBerry? Curve 8330 Cellular Phone
Same deal...buttons not workin...
The keyboard was actin "sticky" for lack of a better techy word. i'd press to type and she'd go nuts and write her own thing. i shut her down (full power) and then she didn't want to turn on. i took the battery out (for the first time - ever) and can only reach the homepage and scroll. i cannot change apps or navigate in any way.
what to do what to do?!?!!?! help.
  • 66 Answers
Water damage
Posted on Jul 01, 2009
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Keyboard keys wont type. used on screen keyboard to type this. any suggestions?
    You might have "sticky keys" so try this:
    When sticky keys are enabled, users can access functions that require pressing multiple modifier keys such as "Ctrl," "Alt" and "Shift" at once by pressing one button at a time. If sticky keys are enabled, it is possible to accidentally turn them on at an unwanted time. After turning off the sticky keys, disable the feature to prevent them from accidentally turning on again.
      • Press the "Shift" button five times in a row to turn off sticky keys.
      • Open the "Start" menu and then click "Control Panel."
      • Click "Ease of Access Center" from within the Control Panel window.
      • Click "Make The Keyboard Easier To Use" from within the Ease of Access Center window.
      • Remove the check-mark beside "Turn On Sticky Keys" to prevent sticky keys from being accidentally turned on.
      • Click "Apply" to save your changes and then click "OK" to close the window.
    Hope this helps. Good Luck!
    Aug 05, 2013 | Toshiba Satellite L645DS4040 Laptop
    Turning off my green keys on HP pavilion desktop keyboard?
    How to turn off Sticky Keys: disable the Ease of Access feature
    Tip: use the Windows Ease of Access Center
    How to turn off Sticky Keys: what are Sticky Keys and why turn them off?
    Sticky Keys is a Windows Ease of Access feature that makes it possible to use keyboard shortcuts or type capital letters without needing to press more than one key at once. Normally, you'd hold down the Shift key while pressing a letter to type a capital, or hold down the Ctrl key while pressing 'S' to save a document. It's even trickier if you want to use a shortcut such as Ctrl-Alt-Del or Ctrl-Shift-Esc.
    With Sticky Keys, you can press Ctrl, Shift or Alt, let go and then press another key - Windows will interpret this as pressing two keys together. You should also hear a beep if you have speakers connected.
    That's great if you're disabled and can't press two keys at once, but what if you want to disable Sticky Keys?
    How to turn off Sticky Keys in Windows 8
    You can't press Shift another five times. Instead, you need to bring up the Start menu (or Start screen in Windows 8) by pressing the Windows key. Now type "ease of access" and click on Ease of Access in the list of results.
    If you're using Windows 8, you need to click on the Ease of Access Keyboard settings result, and then it's a simple case of sliding the Sticky Keys toggle to 'off'.
    If this does not help you. Let us know the below details to understand the issue bettery.
    What is the OS?
    What do you mean by hot keys? ex.......
    Rgds,
    Divya
    Sep 02, 2012 | HP (395366-001) Keyboard
    When i push the e,b,t,a,n ,or r button on my keyboard i get e3 ,bt5,a1, r is shif and nyt
    I have often deal damage keyboard, and type of damage keyboard so much. For damage your experience, a variety of ways have been tried, but the result always failed. The best solution is replace keyboard.
    Based on experience, three times I fix keyboard, without having to replace with a new keyboard.
    First type of damage
    All keyboard keys are not functioning, or functioning left side, right side not working
    Solution
    Remove the keyboard, and cut keyboard cable.
    Second type of damage
    When laptop is powered on, the sound (tiiiiiiiiiiit) so hard. When we press a button, suddenly appeared equal. example;
    I press "y", y appears =======================
    I press enter, appear =======================
    Solution
    Press and release button ~ ` , do it
    repeatedly, when turning on laptop until laptop access the operating system.
    The result is
    1. When laptop turned on, there was no sound. Laptop turns normal.
    2. When I press buttons, does not appear equal to. So all buttons normal function
    3. There are three buttons that do not function [ { , ] } , \ '
    Third type of damage
    When laptop is powered, it looks normal. After entering the desktop, buttons z, x, a, s, q, w, e, does not work. If another buttons is pressed, appear equal. example;
    I press p, appear p=======================
    Solution
    Do not turn on laptop (about 3 weeks)
    This solution does not make sense, there is no technical explanation, and this solution so strange.
    The fact that I experienced
    This case occurred on the Acer Aspire 4736z, OS Win XP Prof.
    After laptop not turned on, more than 3 weeks, keyboard returns to normal. All buttons are functioning normally. I can not explain technically, but this case never happened.
    Solutions for you
    I hope this information useful.
    Dec 04, 2011 | Toshiba Computers & Internet
    HP ProBook 1. Everytime i try to type in a box the screen closes to the desktop 2 my font size always changes; i have to continually change it back to 100, how do i get it to stay.
    Seems the on board keyboard had problems ( sticky ) Have you try using Usb keyboard? I guess the 'Sticky key' is Ctrl or Alt key. you can try pressing Shift key 5 times repetedly ( to disable sticky key )
    Try remap keyboard > ( to disable sticky key with application )
    akee.4shared.com
    Aug 15, 2011 | Computers & Internet
    Whenever I press the NumLock button, it does a sticky key-type beep and the green LED comes on but I am unable to use the keypad still. The same thing happens with the CapsLock key but I am able to use...
    Hello
    In control panel/keybaords. Disable sticky keys.
    Or clean the keyboard with some windex and a rag,try turning it upside down and lightly tapping it to remove dust and dirt.
    Jan 08, 2011 | IOGear GKM502 Keyboard and Mouse
    Some keyboard button not workin on dell laptop
    Did you spill any liquids into the keyboard? If you did you may have damage the keyboard PCB and it will need to be replaced. One thing you can try to do is to first take a picture of the keyboard so you know where the keys go back to that you removed. Then use a small screwdriver to remove the non-functioning keys. Be very careful and do not use too much force or you may damage the key. Inspect the inner buttons and see if they are sticking. You can use a cotton swab or q-tip and rubbing alchohol to try and clean the inner part of the keyboard. Sticky liquids can cause the inner keyboard buttons to stick and mal-function. If the keyboard PCB is damaged you can either replace the keyboard or buy a usb keyboard to use on the laptop. The OS should recognize the keyboard after you plug it in.
    Oct 13, 2009 | Dell Inspiron 1721 17" Notebook PC, AMD...
    Can't type anything without weird things happening the \'p\' prints,
    hi, check that Sticky-keys arent turned on.
    to toggle Sticky-keys on and off, press the shift key 5 times fast, then either Disable the sticky-keys tickbox, or click Settings for more configuration settings.
    when sticky-keys are enabled, you can press shift and release, and the shift key is still enabled. this also goes for Alt, and CTRL.
    so if it is enabled, pressing P will attempt to be Ctrl-P - which is print.
    Sep 10, 2009 | Acer NSK8458AN Keyboard
    When i hold my shift button down it doesn't capitalize the letter...and then when i let go of the shift button and then type the second letter that letter is capitalized. this is supposed to happen when...
    I called up logitech support and they said it isn't the keyboard that was messed up it says that the sticky keys were on which is a Microsoft feature. What you have to do is go to Start, Control Panel, Accessibility Options. When you get in there you go to the box that says Sticky Keys and go into Settings. Uncheck the boxes in the option box that say: Press modifier key twice to lock, and, Turn StickyKeys off if two keys are pressed at once. That worked for me and I am also running Windows XP.
    Jan 29, 2009 | Computers & Internet
    Key board
    the ones on my laptop suddenly stopped aswell. i just kept pressing them down and eventually they started to work again. and fine ever sinse then. hope it helps.
    Jun 23, 2008 | HP OmniBook XE3 Notebook
    RIM BlackBerry? Curve 8330 Cellular Phone Logo
    200 people viewed this question
    Top RIM Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Longtime User
    ismael castillo
    Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
