Question about Jenn-Air JSD2789GES Side by Side Refrigerator
I have a GE side by side that no matter how high I set the thermostat refrigerator side is not cooling also water is running from below freezer side
  • 3 Answers
We had the same problem with ours..we got rid of it,it was happening every single year...what we did was take everything out of the freezer and you will see a metal piece..take the screws off of that (lay old rags or towels down in-side the bottom of the freezer) get a hair dryer and defrost the coils..screw the metal back on and call your local fridge/freezer repair shop and tell them whats going on and they will have to order you a part for it,I can't think of it now, but that should help for a while
Posted on Jul 12, 2009
    Sergeant:
    Champion:
  • 235 Answers
Sounds like your defrost timer is not working. If the back of the freezer has frost built up then your timer is bad.
Posted on Jun 30, 2009
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Refrigerator won't get cold, Thermostat won't stay set to 37F
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Why does freezer automatically defrost and then stay in defrost no matter what we do?
The defrost timer/control board whichever you have is sticking in the defrost mode....replace it...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water accumulating and freezing on bottom of freezer compartment
heatman101
Sep 18, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Sidex side 26 cf... 5 yrs old... frequent water on floor under freezer... freezer temp is erratic and will seldom be below 6, but infrequently will go below 0 setting ..can not keep ice cream
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 28, 2010 | GE Refrigerators
Wat are the two heat rods in bak of freezer
heatman101
Aug 25, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Not cooling
heatman101
uy4
Jul 14, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Poor cooling on frezer and almost no cooling on refrigirator
heatman101
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side refrigerator and frezzer not cooling
FIRST MAKE SURE YOU HAVE IT SET TO DIVERT MORE AIR TO FREEZER SIDE THAN RE FRIG SIDE , MAKE SURE THERMOSTAT IS SET TO COOL ENOUGH , NEXT MAKE SURE SMALL FAN IN REAR OF FREEZER IS RUNNING , SOME MODELS YOU MUST DEPRESS DOOR SWITCH AS YOU WATCH IT , IF FAN IS BAD YOU CAN REPLACE IT YOURSELF REMOVE FAN AND COVER AND MOST UNPLUG , SOME IDEAS
Feb 23, 2009 | Admiral 26 cu. ft. Side-By-Side...
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
165 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
