Question about Apple iPod nano
Ipod and headphone problem
About 2 months ago, whenever I plugged any headphones into my iPod only the left side worked. It works fine on the docking station and the headphones work fine on other equipment, but the two together leaves me with sound in only one ear. Any fixes?
Re: Ipod and headphone problem
Same thing happened to me....makes me wanna throw my iPod out the window.
I have no ways of fixes it, but I do have ways u can listen out of both ears temporarily
Ok so you can push ur finger on the base of the headphones (The part where it is closest to the iPod) and as long as ur pushing (depends on which side, just try push on all sides while listen to music) it plays out of both ears
another way is to pull the base halfway out of the iPod it sucks if ur walking or if the iPods in ur pocket and it falls out easy but this gives better quality sound (except that its a bit quieter than the first way)
I hope i kinda helped
Posted on Apr 04, 2008
  • 515 Answers
The headphone jack on all the apple products have issues (even their laptops). There is no easy fix, other than having the jack replaced, or remounted. A common issue is that it comes loose from the pc board, especially with the movement of the headphone cord. This is a design/functionality flaw.
Hope this helps some.
Posted on Nov 09, 2007
0 characters
3 Points
Don't how to connect iphone to ear speaker
moz-screenshot-12.pngmoz-screenshot-13.pngmoz-screenshot-14.pngmoz-screenshot-15.png honestytessy.jpgHow to Connect an iPod to a Speaker Bar
A speaker bar is a (usually portable) speaker system that includes a dock for an iPod. The unit is usually bar-shaped, with either a rectangular or cylindrical cross-section. Connecting an iPod to a speaker bar is usually as simple as plugging it in. Many speaker bars will also charge the iPod while it is connected. However some do not have an iPod dock, in which case the iPod must be connected by a 3.5mm audio cable.
Things You'll Need:
* 3.5mm cable (for some speaker bars)
Turn the iPod on. Look to see if the speaker bar has a dock for the iPod. The dock will fit an iPod perfectly and will generally be located in the center of the speaker bar. There will be a connector that resembles the connector on the docking cable that came with the iPod. Place the iPod on the docking station and turn on the speaker bar. Such is the case with the "2.1 Channel Bar Speaker with Dock for iPod" or the "Yamaha YAS-71BL Front Surround Speaker System"
iPod headphones use a 3.5mm audio cable.
Connect the iPod via the 3.5mm cable. If the speaker bar does not have a docking station it will have a 3.5mm cable connector with a jack like the headphone jack on iPod ear pods. Plug the 3.5mm cable in the iPod headphone jack. Plug the other end in the iPod. Turn on the speaker bar. The procedure is straight forward and Apple specifically designed the headphone jack with third party stereos in mind.
Select a song on the iPod and play it. The speaker bar will play the music from the iPod.
Hope that helped..
have a nice day.
Feb 23, 2011 | MP3 & Digital Media Players
IPod headphone-socket issues.
make sure the headphones are in all the way! if you have an ipod that doesnt have the speakers built in the it might have just gone bad.
Jan 04, 2010 | Apple iPod touch Second Gen (8 GB,...
For some reason my ipod touch won't play when I plug it into my stereo. It is playing out of the ipod itself. How do I turn this off.
This is a very common problem, you may have to get a different jack that works with the headset jack thats on the iPod. iPhones and iPods have a weird style jack on the top that wont allow most headphone or 3.0mm to 3.0mm jacks to go fully inside the jack causing it so there is not connection with the jack itself in the iPod. You can check this by turning the volume up and down using the rocker buttons on the side while you are at the home screen with no music playing and see if it says speaker or headphones when your turn the volume up and down. Speaker means there is no jack connection, headphone means that there should be music playing through the stereo. Thats using the jack.
If your talking about an iHome or other direct plug in stereo specifically for the iPods and iPhones, make sure that the dock is the correct dock for the iPod, and make sure that it is pressed fully down onto the dock. If all that is correct there should be no problem. If the problem still is happening, it may be your stereo. =/ Goodluck! Hope this helps!
Dec 07, 2009 | Apple iPod touch
Sound does not come out of docking station
It is most likely the 30 pin connector on the Logitech that is the problem. They can break if the incorrect iPod inserts have been used. Try playing someone else's iPod on it, if no go it's busted. Repairs are difficult if not impossible. Sorry
Nov 25, 2009 | MP3 & Digital Media Players
Distorted sound on blue iPod 8GB nano
make sure heasdphones are plugged in completely
May 22, 2009 | Apple iPod nano
Ihome won't play ipod, even after resetting ipod I have de same problem. I got an itouch 2nd generation and docked it on a speaker that supports it. It worked fine for two or three hours, but suddenly it...
Welcome to the wonderful world of the iHome frying the Ipod.
Your iHome, has most likely fried the mainboard on your ipod.
to check plug a usb into the ipod and connect to the computer.
if it comes up disconnect the usb and try a headphones in the jack.
if it doesn;t play sound its fried and you will need a new mainboard.
if it does play through the headphone jack, your lucky and keep it off the dock.
I have fixed at least 30 ipods taken out by ihome docks and other docks.
they are terrible for the ipod. Even Apple sells the docks on their website
that shows how much they care about the product.
If this helps leave a vote on fixya
May 11, 2009 | Apple iPod touch
I own an Apple Ipod video which I bought in 2006. It worked just fine for about 9 months at which point I could not get any sound(music) from the headphones or when plugged in via the usb dock to my car...
If all your music is in iTunes, format and restore the iPod to a Mac formatted iPod in iTunes. There are some firmware updates as well, which restoring will give you, and these should help. After doing so, iTunes will copy all your music back to the ipod.
Dec 11, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod plays with no volume
If the sound isn't working from the headphones then normally it's just a new headphone/hold switch cable that's needed, but if it's not working from the docking bay either then you have a problem with your logic board.
Oct 26, 2008 | Apple iPod MA446LL/A MP3 Player
Nano shows song playing but nothing happens
Make sure your headphones are working properly by testing with your computer headphone jack.
Is the headphone port on the Nano loose?
Connect the Nano to your iPod dock and see if you can head audio through the docks headphone jack.
If the headphones work, and you can get audio out of the dock headphone port, then there is a problem with your Nanos headphone jack.
Apr 07, 2008 | Apple iPod nano 3rd Generation
Apple iPod nano Logo
144 people viewed this question
Top Apple MP3 & Digital Media Players Experts
 Mike M
Mike M
Ron Dufek
Ron Dufek
Raisin Brann
Level 1 Expert
Are you an Apple MP3 and Digital Media Player Expert? Answer questions, earn points and help others
