Question about Kenmore 98702 Stacked Washer/Dryer
Need to change wiring from 220V to 110V
I just bought a stack unit 120V/240V and want to have it run on 120V....any know the wiring diagram?
    Sergeant:
    Champion:
  • 235 Answers
Black or red is hot; green is ground; white is your neutral. The black should be for 120 and the red for 220.
Posted on Jun 30, 2009
I bought an Epson scanner from America with a power supply for 100v-120v can I still use this in Australia which has 240v. Regards ****
hi,
see the power rating on the power pack adapter. Unless otherwise stated,
most come with an international standard of 220v. I bet you can find an adapter with the right capacity that fits your scanner if that doesn't work.
Hope this helps
pls rate or vote this
Jul 05, 2011 | Epson Perfection V200 Flatbed Scanner
Dear sir I am trying to connect Model Et104, my questions are as follows: I am having a problem connectiing your system. Both power source 110v and 220 volts have to connect to your system???? If my...
Fixya answers questions about other people's products.
I specialize in timers.
Intermatic is changing their product line
I suggest you download the manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et104c%20-%20english.ashx
The manual is generic across all the ET100 series products.
The manual does not describe individual models.
The instructions are on the timer door.
Look for the clock voltage.
The clock voltage tells the story of your timer model.
NOW lets say your clock voltage is 120V.
I believe you suspect the clock voltage is 120V.
To make this timer work with your 240V cable, there are 2 methods
Method 1) To meet code, run a white wire from nearby 120V receptacle.
This is a Neutral wire.
Connect the Neutral to terminal 1
Connect one leg from the 240V cable (1 of the 240V wires) to terminal 2 and that will complete the 120V circuit and the clock will run.
This is true because each leg of a 240V circuit is actually 120V, and only when the two legs are combined do they produce the 240V circuit
Method 2) Connect bare ground wire to terminal 1 and to grounding screw
The bare wire connects to the Neutral busbar in the main breaker box, so it will complete the 120V circuit just as described above.
This is not code, but your clock will operate.
Then connect one leg from the 240V cable to the terminal 2
IF your clock is 240 V, then connect both legs of the 240V cable to terminals 1 and 2
7:59 CST Add a comment if you need more assistance, I will be here later this evening
Nov 06, 2010 | Intermatic INC ET104C 24 HOUR ELECTRONIC...
I have a question, why there are 2 voltage in American market? where uses 110v, and where uses 250v? We are a manufacturer of power cords , power supply cords, we really want to know the difference ....
110V is our common household current and 220v is used where heavier voltage is needed, like ovens, stoves, clothes dryers, air conditioners, electric water heaters, arch welders, etc.
Dec 18, 2009 | Computers & Internet
Change voltage from 120v to 240v sony bravia 37L4000
I think that Sony Bravia are sold with dual voltage, 110V and 220V. All 220V devices work also on British 240V network.
If an electronic device is not compatible with the 240V/220V network, then the PSU must be replaced.
In your case the unit should be dual voltage, compatible with 220/240V networks. Just ensure checking the user manual, or the tag at the back of TV.
All you need in that case is an adapter that can be purchased at any local electrical shop (eg. Curry's if you are in UK).
Regards.
Jul 26, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Changed power supply from 110v to 220v, now get 50.2 fuser error
The printer will have a 120v fuser, unkess that has been changed for a 220v fuser, it won't get up to temprature on 220v, hence the error message.
It needs a 220v fuser.
May 05, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
Power conversion
Ram,
Good day mate, no problem you can plug your dvd direct to your outlet since it indicates 100 - 240V it only means your player is capable of having either 110V 0r 220V.
note: also try to check 1st if you will see a voltage selector at the back of your dvd player. it's either a slide switch indicating 110 or 220V. if no sign of this selector no problem you can plug your player straight to your socket.
cheers
mark
Jan 29, 2009 | Durabrand DVD-1002 DVD Player
How to change tension from 120V to 220V
If you are sending a sewing machine which runs on 120volts to a region that has a 240volt power supply you will need to get a
power step down converter that will fit into the socket of the 220volt supply ,and will have a socket that will hold the plug of the 120volt supply going to your machine.
the converter must reduce the 240v down to 110v .
Aug 01, 2008 | Brother Sewing Machines
Usa to uk
Hi mick
the unit has a voltage selector switch on the rear. Have you selected the 220v option. this will solve your need for a reduction transformer. If you have just gone ahead and fired it up in 110volt settings.... internal damage may have already occurred.
What is the switch set to now? Let me know
regards
Graeme
Feb 17, 2008 | Onkyo TX-SR605 Receiver
Change 120v chager to run on 240v
all you needs is a step tranformer from 110v to 220v ac
Nov 13, 2007 | Dewalt 7.2-18.0 Volt One Hour Charger
Kenmore 98702 Stacked Washer/Dryer Logo
650 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
