Question about Rheem Water Heaters
We get a smell from the water - Rheem Water Heaters
  • 117 Answers
Try flushing out the hot water heater, they usually get build up in them which can cause smell. if not look for what they call a charcoal filter and install it after the water heater or any filter that will filter oder and taste. 3m makes a nice one and so does CUNO
Posted on Jul 29, 2009
Is it normal to smell a faint gas smell near new installation tankless water heater. Installed yesterday.
no
gas smells indicate a deadly situation as an explosion and fire from the build up of gas is a very real possibility
get in a gas fitter with a gas detector to find and fix the leak
Sep 08, 2017 | Water Water Heaters
What could be the problem causing the rotten egg smell in the water? We have changed the anode rod.shocked the well.no sulfur. We have kinetico softener. Use iron out salt. Water heater 2 yrs old.
Some water softeners you can increase the back wash time on the unit to clear out a smell or bad taste , rotten egg smell can be sulfur. You may need a well flush but seek a well company on that for there advice as its not cheap .
May 16, 2017 | Water Water Heaters
When a electric water heater smoking and it gits turned off at the breaker box will there be a chemical smell after
No. A water heater is a sealed system it needs to be addressed for the original problem. High sulfur content has been a complaint as far as smell,and I remove the anode and replace with a brass plug because of. Shallow wells in the area largest complaints.
Nov 27, 2014 | State Water Heaters 40 Gallon Select SL...
About every two months the the hot water gets a sour smell. To get the smell out I turn both elements all the way up for 3 hours then drain the water heater, its good for about two months. The water heater...
The smell is from bacteria. The high temperature kills the bacteria. Some regions require water heater temp to be set at 135 because of bacteria.
A test to determine if only the water heater is causing problem: Turn off water to water heater. Smell water coming out of cold tap. Turn on water to heater, smell water from hot tap. If only hot tap smells, then water heater is suspect.
Another way to handle the problem long-term, is to reconfigure cold water pipes so you can regularly pour in 2 bottles of hydrogen peroxide during your flushing procedure. Pour in the hydrogen peroxide and let it work for a while. And then flush tank as you have been doing.
You should read up on anode rods also. Many people replace anode rods when tank begins to get odor.
http://www.waterheaterrescue.com/pages/WHRpages/English/Longevity/water-heater-anodes.html
http://waterheatertimer.org/Replace-anode-rod.html
Oct 23, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Hot water smells
The anode rod can affect the smell of your water. They are often different materials depending on where you are in the country... if you have magnesium then change it to aluminum or vice versa...
Also check out this tip I wrote about water and sulphur smell...
http://www.fixya.com/support/r3571436-well_water_with_a_sulphur_smell_can_be_f
Heatman101
Mar 21, 2010 | Rheem Water Heaters
Sulphur smell
you can remove it but this will not fix your problem, you must cut the cold side pour in about half gallon of bleach ,drain heater of a gallon and a half first, then pour in bleach wait one hour then use as normal. you will have a bleach smell for some time but this will make the egg smell disapate.try this it worked for me.
Jul 21, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
We get an smell from the water
If the smell is somewhat like sulphur, a nipple from a nat gas line was installed into the water line when the water heater was installed. If this is the case replace the nipple and the smell will go away
Jun 30, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Atwood heater problems
The smell is from the (anode rod not sure of this term is exact) in the water hater. Smells like rotten eggs. You have to remove the rod in the top of the water heater. This will void the warranty of the heater. The soot is due to flame adjustment. this should be done by a professional.
Jun 18, 2009 | RTO Atwood Water Heater - 6 Gal LP
The hot water smells like rotten eggs., only the hot water
its the mag rod in water heater-if your not using alot of hot water,and water is sitting in heater it will smell like rotten eggs-u can remove mag rod from water heater.it is in top of heater-
Jan 08, 2009 | General Electric GE SmartWater Household...
Water Heaters Logo
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
