Question about HP PSC 2410 All-In-One InkJet Printer
Noise on my printer HP psc 2410
My printer will not start and it is making a weird noise
  • 1 more comment
  • Anonymous Nov 10, 2007
    Hello
    I have the same problem, when i start the printer, the sacnner move some inches and then return to the initial point and make a strange noise. I try the solution pressing the cancel button before strat the printer, but the problem continue.
    Thanks and Best regrads
    Carlos
  • ez2jinx Nov 19, 2007
    I have the same problem as described... when the the is 2410xi is powered on, the scanner moves back and forth, then moves back to what looks like a landing or starting point for it to stop, however, it keeps moving and doesn stop....which makes this clicking sound from the belt inside that is still moving. Eventually the 2410xi times out and shuts off.
  • Vic Wong Sep 21, 2013
    http://www.ifixit.com/Guide/Cleaning+the...
I have experienced this problem numerous times since owning theprinter, and usually a full reset (# and 9 on power-up) has resolvedit. Not this time, however! Following Guest's advice above, I visitedwww.fixyourownprinter.com and found the solution: cleaning the glass. Thank you, Guest!
Freddy
Posted on Dec 18, 2008
    New Friend:
Http://www.ifixit.com/Guide/Cleaning+the+Scanner+Glass/5591/1
Click the link above to see the pictures "How to take the scanner
Glass out and clean it. I did follow each step and now the printer and scanner work like new.
Posted on Sep 21, 2013
My printer starts up then moves back and forth continues to mqke noises like it is printing then green on light continues to blink.
Posted on Dec 13, 2008
Refer to solutions at:
http://www.fixyourownprinter.com/forums/printer/36708
One or more may help you for a while.
Posted on Dec 23, 2007
Can't print or copy anything printer just sits and makes clicking noise.I bought a PSC 2210 and it started doing this.I got rid of it and got a PSC 2410 and now it is doing the same thing. What's...
Hi
This is a common problem with these models. Any ways this is a problem with the cable connecting from logic board to the scanner assy. replacement is the best solution
Jul 15, 2011 | HP PSC 2210 All-In-One InkJet Printer
My printer is making a weird noise and the power light just blinks
Turn off the Printer
open the Front access Door, Check if there is bits of paper or dirt on the ROD that moves the Cartrige/carriage.
Move the Carriage freely 5-6 times from left to right ( it should move smoothly )
Remove the Cartridges, Clean the contacts on the Cartridge ( golden Contacts)
Open the Rear Access door, Clean the Rollers with lint free cloth.
Close the Rear access door and front door
Power on the Printer. If the grinding noise continues, Unplug the power cable from back of printer ( while printer is on ) and while holding the # and 6 button, connect it back.
It should go thru alignment process and the grinding noise should be gone. If it doesnt, probably.. its time for new printer of HP again.
Jun 24, 2010 | HP PSC 2410 All-In-One InkJet Printer
Loud clicking noise when turn on printer
I would check wherever possible for foreign objects in the printer. Failing that, a partial reset is available for your PSC 2410:
A partial reset can be done by:
1) Unplugging the power cord (you are already there!)
2) Press and hold the (#) key and (3) key while plugging the unit back in
Dec 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
Why is my hp psc 2410 photosmart all-in-one make a clicking noise, when I turn it on? It seems to be stuck in a "cycle". Like the printing carriage (if that's what you call it) is hooked-up.
See if you can press the power button to turn it off, leave it for 5 minutes then turn it on again, if the clicking persists again try 1 more time, turn off, leave for 5 mins then turn back on this time there should be no clicking noise and you should be able to send a print job to the queue and it should print.
If this doesnt work then goto the hp software and purge.
Oct 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
Makes noise on scaner
it needs servicing to work properly.as something is blocking the gears to move freely so the noise is coming and led is flashing.
Oct 23, 2008 | HP PSC 2410 All-In-One InkJet Printer
Hp psc 2410 photosmart all-in-one
scanner replacement is needed as this cannot be repaired,the lower printer part is perfect just the scanner parts needs replacement.it is also costly to get replaced.
Sep 29, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet printer default settings
Please can i obtain advice on how to reset my printer, as i am getting funny noises from it and nothing else.
Jul 13, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
748 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
