Question about Rv Motorhome Dual Co & Lp Gas Alarm Detector
I need a wiring diagram for a alternator/battery isolator
My alternator isn't charging my starting battery in my 87 Bounder RV. I replaced the alternator, although it checked good, because the bearing was making noise. That didn't fix the problem. I'm not sure how the alternator connects to the battery through my Transpo 2-130A Battery Isolator or how much voltage should be present on my battery with the car running. It's only 12 volts, so I know that it won't get any charging, and I'm wondering if the battery isolator could be that problem. Should I be getting somewhere around 14 volts out of the isolator going to the battery? Any help would be appreciated...
And Carol, I'm not exactly sure what you're asking, but I just replaced my alternator and the belt was pretty self-explanatory. What problem are you having?
Thanks.
  • y2jconley Jul 01, 2009
    Thanks for the help. All batteries are brand new but the engine battery ran down on a 30 mile trip. I pulled it and had it checked and charged. I'm only reading 12.3 volts, or so, at the battery with the motor running. I pulled the alternator and had it checked and it checked good - 14 volts. I replaced it anyway because the bearing was making a little noise. I suspect that I must have a bad isolator but am not really sure how it's wired and how I should check it. One cable goes to the + side of the marine battery and one goes to the engine battery. Those should check 14 volts, or so, from the ground side of the batteries. Yes?
I have a pop up trailer and would like to go camping self contained. This means that I need to hook up the battery to the trailer. I don't know how to get a wiring diagram for this job. How do you hook it up. I need to run lights and furnance fan. The trailer is a Rockwood bought it brand new in 1997
Posted on Jul 19, 2009
    President:
  • 1,114 Answers
The isolator should have from 12v-14.3v to the batt. Check the battery itself. If it's a marine battery check the cells for white chalky powder (signs of an internal short in the battery) Also check the distilled water level in the battery. Hope this helps. If you still have an issue, post a comment and I can help you troubleshoot further
Posted on Jul 01, 2009
How do I change the alternator on my 87 bounder
Are you sure it is bad? Take it to a place like NAPA which sells batteries and get them to but the tester on it to be sure. When you have done this, answer and I will walk you through the process of changing the alternator or you might check what NAPA would charge you for the work.
May 24, 2015 | Cars & Trucks
No charge voltage to battery. New alternator. No turn signals. This vehicle lost charging when towing trailer.
Troubleshoot by isolating the alternator, then testing for a 13.5 - 16v output (likely to be ~14.5v). Anything out of that range indicates bad alternator or voltage regulator (assumed to be built into the alternator). If voltage is in range, (and following your suspicion of an electrical problem in the Turn Signal circuit), reconnect the alternator and isolate the turn signal circuit by pull the fuses. See if you are getting the good voltage reading of (~14.5v) at the battery. IF IT'S GOOD..check for bad trailing wiring harness (isolate if possible), I've seen bad turn signal bulbs (contacts on bottom of bulb) short out (melt) in their sockets (typically causing a blown fuse..but ya'never know), and lastly you might have to do a hand over hand following the wiring, looking for shorts, melted wire, cuts, broken connections, etc (see Hanes Manual Wiring diagrams for possible points to perform continuity checks). IF IT'S BAD. you must continue to isolate electrical circuits until you find the one that is causing the fault. You can pull one fuse at a time (not reinstalling them) until voltage at the battery returns, or you might try pulling a group of fuses at a time until you can read good voltage at the battery, then replace the fuses one at a time until you find the bad circuit. Once you've isolated the bad circuit, it's either a matter of further isolation until you find the bad component (many circuits supply voltage to multiple components), or checking every connection and component connected in the circuit. Best of luck resolving this problem.
Dec 10, 2013 | 2006 Toyota 4Runner
I think my alternator isn't wired right. I need a diagram so I can rewire it. Does anybody have one?
And if you could tell us the year, make, and specific model we might be able to help
Jan 19, 2013 | Cars & Trucks
Install battery isolator
if it is just the one battery, put the isolator on the ground wire
if the ground wire is turned off by the isolator , there is no circuit
Apr 16, 2017 | Chevrolet Cars & Trucks
87 harley sporster charging
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12.5 volts or better after charging.
3. Hook up battery positive cable, then with your multimeter on the milliamp scale connect one lead to the negative battery post and the other lead to the ground cable. Meter should read 3 milliamps or less, 10 milliamps with a radio, 15 milliamps with radio and CB. If your meter reads higher you need to isolate the circuit by pulling fuses and circuit breakers one at a time and observe meter for drop in aprerage then get out your test light and track down the short in that circuit.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v while cranking replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor.
17. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Sep 22, 2012 | 2005 Harley Davidson XL 1200 C Sportster...
Wire diagram for chevy 3500 van
When you say charging,do you mean amp reading or volt reading?Amps should rise when first started then drop.Volts should stay close to constant.The small wire going to the alternator to power the regulator in the alternator is just switched power.If the volts fall under 14 after ten minutes you may need to try a replacement alternator.
Apr 28, 2017 | Chevrolet Express Cars & Trucks
Actually its an 87 but still a bronco
looks like you burnt the fuseable link from the alternator . you need to check the voltage at the back of the alternator on the red heavy wire with the battery fully charged and key off you should have battery volts at this terminal and if there is voltage you need to put a load on that wire with a 12 volt light bulb. . the bottom line is your charging system isnt working . so we need to find where it has lost its connection. let me know if this doesnt work and ill send a wiring diagram with directions.
Aug 24, 2008 | 1995 Ford Bronco
Rv Motorhome  Dual Co & Lp Gas Alarm Detector Logo
6,001 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
