Question about Vacuums
Installed a used engine on a 1996 Toyota Avalon xls, and need a vacuum hose diagram so I can run new hoses properly.
  • mogul1171 Jun 30, 2009
    I know, however I still have hoses left over after following that diagram.
    Sergeant:
    Champion:
  • 235 Answers
Your dealer should have the schematic for your vacuum lines. If not , Auto Zone sells the manual for your car type. However, it is not uncommon to have hoses left over. The extra hoses could be for accessories your car is not equipped with. Hope this helps.
Posted on Jun 30, 2009
    Top Expert:
  • Vacuums Master
  • 80,637 Answers
There is a vacuum hose diagram under the hood at the vehicle emission sticker, this is unique to your calibration and car
  • yadayada
    yadayada Jun 30, 2009
    you are going to need a factory manual for these
I need a hose diagram
Hi, it's Ambrai from Crucial Vacuum.
I have inserted a link that will direct you to your ProHeat's User Guide: http://www.bissell.com/assets/0/132/134/228/37c9e5f4-f551-4b35-917f-33c0e7055ea9.pdf
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Ambrai Brown
Crucial Vacuum Customer Care
http://www.crucialvacuum.com
May 13, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Engine is running properly; no suction; hose attached properly and it is not plugged, what to do?
Look for trapped lint in the hole up and behind the beater bar. Down in the hole the hose hooks to. This a general answer and not specific.
Dec 14, 2013 | Dirt Devil Quick Power Cyclonic Upright...
Kirbyg4 shutting off while in use
First thing to check is cord to make sure no bad spots anywhere. If the bag emptor is not installed properly there is a switch that will not allow vacuum to run. There is another switch that is depressed when the power nozzle, hose or carpet cleaner is installed on the front of your Kirby. If the switch is not being depressed properly it can keep the vacuum from running.
Oct 26, 2013 | Hoover U5180-900 Vacuum
I have a S3765 Hoover Wind Tunnel with a crack in the hose close to the cannister. I know wires run through the hose and that there are wire connections on either end of the hose. The replacement hose...
If the vacuum has been maintained properly and runs well it may be worth repairing. The hose is pricey but less than a new vacuum. Many new vacuums today, especially lower priced ones are very poor quality and don't last much longer than a year. It appears by the schematics of your model you can replace just the hose section or the entire hose assembly. Replacing the hose only would require removing the ends of your old hose and installing them on the new hose.
Sep 28, 2017 | Hoover S3670 Bagged Canister Vacuum
How to replace the flexible hose between the upright and floor modules?
Turn the vacuum on it's side. Pull the power nozzle end out. Unscrew, in a clockwise direction, the hose from the body/tank.
Reverse to install new hose. Screw the hose into the tank, turning counter-clockwise. Place other end into power nozzle. Ensure it's set properly.
Dec 31, 2010 | Electrolux Epic 3500 Vacuum
Need help putting my bissell carpet shampooer back together
the side that is dragging needs the roller that the brushes are on ,to be precisly pushed back up in it's place,it will take a few minutes and it will not slide back in place easily just use a little force as for the hose diagram, bissell.com,enter model number and go to hoses.
May 31, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
My hoover mach 6 bagless overheats, shuts off for about an 1 hr will run again, all filters are clean, no blocks in hoses, how can i fix this problem
This is telling you that there is poor air flow or a blockage somewhere. To simply check for proper suction, remove the accessory hose to see if there is normal suction, if not then your problem is further in the unit. Troubleshooting from there will tell you where the problem is. Another possibility is that your thermal overload circuit is faulty. in this case a pro vac shop needs to service the issue.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Feb 28, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Vacuum clogged
If you are talking about the electric hose, try using your none electric hose with the crevice tool attachment to extract the particles from the other one. When using any of the hose please leave it running a few minutes to make sure everything in the hose moves through and does not stop midway through.
Jan 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Tear in Eureka Upright "The Boss" 4870
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=652524
Posted by kdunnett on Jun 07, 2008
I have a tear in the hose of an upright Eureka "The Boss" 4870 vacuum. I cannot find how to release the parts I need to get the hose out and put in a new hose (which I already have) I've searched the Eureka site and the owner's manual - nothing about how to replace the hose itself. Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. In answer to your question, the owner’s manual may or may not give an example to install the hose only, but on most vacuums the hose sometimes will screw in to the hose cuff on both ends unless if it is a hose assm then it will then twist and turn. Check with the
Eureka website and have them send out a schematic and owner’s manual for you so that you can install your hose properly. Sometimes you have to place hose glue on the end of each side in order for the hose to screw in properly. the website address will be listed below and they certainly should supply you with the owners’ manual and maybe a schematic of the parts breakdown that also may help. If not; check with your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 07, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Vacuums Logo
85 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
