Question about Kenmore 72055 Air Conditioner
Need manual need to find out how to get the front cover off. Don't have a manual.
  • lobster12953 Jun 30, 2009
    actual model is 25370055990
    Scholar:
  • 70 Answers
Google make model number and say onwers manual. This may get you there.
Posted on Jun 30, 2009
How do I adjust the valves on my 1996 camaro 3.8 v6
I don't belive there are on that engine .Although i could be wrong i don't have that manual in front of me. Pull one of the valve covers see if there are sloted studs and lock nuts on the valve side of the rocker arms. If not you have a stuck lifter. If so the adjustment would be 17 thousands for the ehxust and 15 for the intake but it needs to be done in sequence .Call the chevy dealer it has to be done correctly or you will start throughing rods through the hood. Im 90 %there not and its a lifter
Mar 06, 2012 | 1996 Chevrolet Camaro
Need to replace the pull cord
Hello, you will need to pull the front cooling cover on the chain saw.. There will be some screws but normal they will tor-ex screw/Allen head screws. Now look at the front cover and where the pull rope goes through it---they might be some holding a cover over the pull rope mechanism. If there are then your are in luck. You wouldn't have to take the front air shroud off.
But, if you have to take the front air shroud off, remove the screws, the handle bar, empty the fuel and oil reservoirs and leave the caps.
DON'T REMOVE the kick back handle. This connected to a braking system, so just leave it alone.
I don't know what type of chain saw you have and this a general type of instruction for remove the front cover on you chain saw. I wish you lots of luck. Just take your time and you will get done. GB...stewbison
Sep 05, 2011 | Garden
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
"Check Filter" light is on.
If you look thru the front panel just behind it you will see a spong filter. you will need to access it either by removing the front cover or removing the whole front of the unit . wash it in warm soapy water and replace it . let me know
Jul 21, 2011 | Frigidaire FAA065M7A Air Conditioner
I don't have a manual, but I need to get inside to
Unplug the dryer and remove it to the outside if possible.
Remove them lid switch wires off and raise upwards on the front to release the bottom clips.
You will see this:
Get the tub out and it will look like this
Get the back dust cover off
Service manual, repair videos, and MORE HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 06, 2011 | Kenmore 64952 Electric Dryer
I just got this from a panw shop, it doesn't work it need a battery and I take it it also need a charger for the battery, where is the best place to get one of each, can I get one from the factory, along...
OK, first it doesn't need a charger. Most charger are external types. Battery, it probably uses one (1) CR123A which is a three (3) volt battery, or two (2) "AA" batteries which are rated at 1 1/2 volts each. Batteries you can get them every where, Radio Shack, WalMart, Kmart, Sam's, Walgreen's, One Stop Batteries, etc. The average life for the CR123A is about twenty hours of use, and it probably the same for the double "AA's.
Here how this Famous Trails End NV FT300 Monocular work. The monocular has two button-one for on/off, and the other is for the IR luminations.
.WARNING!!!! This a night vision devise will be used at Night! Don't taking a look see at bright lights or using the night vision devise during the day... Light time.
Now the monocular has a build in shut off for to much light entering the image tube. Don't try it, it works. The more times the monocular NV is subjected to bright lights the more it destroys the thinly film cover over the plate. One it gone, new image intensifier tube and the cost will be about $200 plus shipping and handling.If you just have to take a look see in the monocular. Get a couple of optic lens cover that snap on. The front Optic cover drill about 1/16 in hole in the center of the cap, that it. Now you can take the back lens cover and remove it. Turn your monocular on and take a look through the eye piece. It should be green, if not, take it back the Pawn Shop and ask for a refund.
If you don't have lens covers that OK too. Just get in dark room and point the monocular at one of the corners. Don't point it any lights. It will turn green. I will advise you don't test the auto shut off. You don't know who had first, second or even third time, how it was handed and used. stewbison
Feb 06, 2011 | Famous Trails Ariel FT300 Monocular
My Brother HL-2040 paper led light won't stop flashing, the paper's not jammed or anything, I just put in a new toner, too. I tried doing what someone else said about opening the cover and holding Go until...
Hi. The reasons listed in the manual that cause the LED to flash normally are:
Front cover is open
Close the front cover of the printer.
Back cover is open
Close the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 6-5.
If the printer does not start printing, press the Go button.
No paper fed manual feed slot
Put the paper in the manual feed slot. See Printing on plain paper, bond paper
or transparencies from the manual feed slot on page 1-10 or Printing on thick
paper, labels and envelopes from the manual feed slot on page 1-13.
Memory full
The printer memory is full and the printer cannot print full pages of a
document. See Solving print problems on page 6-15.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
Drum Error
The corona wire needs to be cleaned. See Cleaning the corona wire on page 5-14.
If you check out page 6-5 it tells how to clear the paper jam from the rear of the machine! A point often missed.
Check out the website below if you don’t have a copy of the instruction manual =
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002089/US_Eur.pdf
If all else fails, try a reset of the printer Drum & Page counter:
  1. With printer tuned on.
  2. Press and hold the “internal button” behind front cover, until all LEDs illuminate.
  3. Make sure Drum light is off, then release and close front cover.
Hope some of this helps………..Please post a response back here and let us all know if it works?............Regards, Cornwellnet (UK)
Jul 12, 2009 | Brother HL-2040 Laser Printer
Frozen screen
Facing the GPS system, remove the front cover with your nail or something sharp and under it you will find a reset button. If needed, refer to page 30 in the manual (see website below) for pictures:
www.tramsoft.ch/downloads/garmin/streetpilot-c550_owners-manual.pdf
Please don’t forget to rate my answer.
Nov 13, 2007 | Garmin StreetPilot c550 GPS Receiver
Screen frozen
GArmin c340
Facing the GPS system, remove the front cover with your nail or something sharp and under it you will find a reset button. If needed, refer to page 30 in this manual (different model but same principle, see website below) for pictures:
Oct 11, 2007 | Garmin StreetPilot c340 GPS Receiver
Kenmore 72055 Air Conditioner Logo
242 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
