FixYa.com
Tags:
IBM Z100  ZIP Drive
HD-Controller
By kcw573 - usenet poster
I hope that someone can help me with my Z100 and the problems with
the harddiskcontroller.
Even my MSDOS has eroors and I want to get CP/M for that nice machine.
Under MSDOS I can format the harddisk well and there are no problems
during formating. But when I will put the system on the Hdarddisk an
will boot the come the message " Harddisk not ready " .
The Harddisk are ok, at the moment thei are well running on my NCR DMV
and I beleave that my SYSDISK is danaged or the controller makes the
problems. I even have only the usermanual for the Harddiskcontroller
and would need the service manuals for it.
If you can help send me a message..
Thanks
Fritz Chwolka / collecting old computers just for fun
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Nov 28, 2007
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The original Z-100 HD's were 20 MB or less and formated with 512K blocks. If you have put in a larger HD and used the K switch to get the whole HD then neither the original ZDOS or Zenith version of CPM86 will recognize thew hard drive. You may need to put in two 20MB HDs instead of one 40 MB.
Rich
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 07, 2005
Not Rated (0)
Bray
Bray - usenet poster
Rating: 0%, 0 votes
I used to see this when I installed a genuine IBM HD.  There is a ready
signal that was not used my IBM, and the Z-100 would try to boot before
the drive was ready.
If this is the problem, you can try booting up after the drive is up to
speed.  If you have auto-boot enabled, you may have to reset the system
or abort the auto-boot until the drive is up to speed.  I always used
manual boot for this reason.
Hope that helps.
Primary addr:   bbs.rus @tsoft.net (UUCP apple.com!tsoft!bbs.ruscal)
                Tsoft Public Access Unix, Mt. View, CA 415/428-0190
Secondary addr: rus @west.darkside.com (Home of Waffle BBS Software)
"The last run of Twinkies was 1978; If you want'm fresh, wait'l 1996."
Solution #3
Not Rated (0)
Gary10
Gary10 - usenet poster
Rating: 0%, 0 votes
Also there is another problem which may or may be present.  The Z-100, before
MS-DOS 4.01, uses 18 sectors/track instead of IBM's 17 sectors/track.  If you
are still having problems, you could get MS-DOS 4.01 and Monitor-100 ROM
upgrade (3.2) which rewrites the BIOS for the Z and uses the IBM format.  It
also makes it possible to use Hard Drive greater than 32 MB, and HD drives,
and Dual Density drives from the 34-pin connector or HD drives (5 1/4 and/or
3 1/2) from the 50-pin connector and configure them for any drive letter
and boot from any drive connected to the Z.  If you did not PREP the Hard
Drive you are having problems with, this method should mean that you do not
have to reprep the drive.  The MS-DOS 4.01 is available from Paul Herman, Inc.
or directly from Parts Is Parts in New Jersey.  I don't have Mike's address
in NJ but I do have the address for Paul Herman it is:
Paul F. Herman, Inc.
9317 Amazon Drive
New Port Richey, FL  34655
Bus # 813-376-5457
Order Line 1-800-346-2152
The price of MS-DOS 4.01 is $89.  The price of ZPC, a software emulation of
the PC is $29.  Also ask him about the buy-back of your Registered copy of
MS-DOS 3.x for the Z-100 that he is looking for.  If you do not take advantage
of MS-DOS 4.01 and its IBM-like 17 sectors/track, you will need to PREP ANY
genuine IBM-like drive to get the Z-100's 18 sectors/track.  If you do prep
your drive, you will get a partition for MS-DOS and a partition for CP/M.
Then if you decide to get DOS 4.01, you will have to reprep the drive to
get the 17 sectors/track format back.  Paul has Mike Zinkow's address and
phone number so he can help you in the installation.  There is a lot more
stuff you can get from Paul Herman, Mike Zinkow, and others would are trying
to keep the Z-100 alive and well.  There was also a discussion about replacing
the 8088 with a 486 mini-board to get a super-fast Z-100, plus other things.
I hope this helps.
Jerry W. Cox
Can you Help with these Zip and Other Drives problems?
flash disk 2G type kingston
ma flash disk est protiger par... Answer This...
2 GB quantum pen drive problem
Hi i have 2 GB quantum pen... Answer This...
Write protection problems
I have a Tarcscend 1GB pen... Answer This...
Sound Volume Driver Cannot...
My NoteBook Compaq V3000 Sound... Answer This...
PNY Optima Attache 4G
Cannot open files or format.... Answer This...
Repair Service
Find Zip and Other Dri. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
