Question about GE (PSS26MSRSS) Side by Side Refrigerator
Which way does the fan rotate on a GE side by side. I can't remember.
    Sergeant:
    Champion:
  • 235 Answers
The rotation should be where it blows towards the front of the fridge.
Posted on Jun 30, 2009
I just replaced the motor to the condenser fan, after I put the blade back on, and finally got everything moved and screwed back down I am wondering if I put the blade on so the air flow is going in t
If you replaced the fan motor with the correct rotation replacement motor the fan should be blowing in the right direction or did I misunderstand what you are trying to explain? Sea Breeze If the part number is=> WR60X187 the motor should be turning clockwise rotation while looking at the motor from the rear. Thanks JT
Jan 26, 2013 | GE Monogram Side by Side Refrigerator
Freezer fan stops runing after GE tech did something and left i noticed he touched the relay... appreciate any help you might offer thanks. nick
try to re inserted the terminals of your relay or check the resistance of coil of relay and the contacts if ok if not replace it also the fan motor check the resistance or the continuity using ohmmeter or rotate the fan blade maybe it is stock up apply lubricants. then observe unit after you perform repair if problem persist call GE tech possibilities ther is a warranty after he repair your ref .
Mar 06, 2011 | GE Refrigerators
Ref not cooling enough, condensor fan rotating very slow
if the condensor fan is rotating slowly then you should replace the fan also assure that there is no ice build up on the condensor as well you can find your part going to www.marcone.com under contact us there is a 1800 number this is the cheapest appliance parts place in the world we use this company to order the parts that we replace for customers if you do have an ice up situation you might want to do a continuity test with the unit unplugged on the defrost thermostat if you have any further questions message me back Thanks again Rick
Jan 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Fan in freezer section of an upright Bosch fridge freezer has stopped working.The fan is not iced up and moves freely when manually rotated Both sections of the frig are keeping cold but not achieving the...
Sorry to read about your problem, I hope this helps you out.
the fan could be defective,
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram ZISW36DYA ... frozen ice-cycle rivulets run down both sides of freezer (water off for days to verify it is not ice maker) ... defrost control clicks when rotated and advances with time ... do...
Seems to me that might be a clogged defrost drain or maybe a dripping water valve. Doing that. I have the service manual with nice pictures in it that show clearly how to access the components.
GE MONOGRAM SERVICE MANUAL
Nov 10, 2010 | GE Monogram Side by Side Refrigerator
Convection oven making rattling sound.
It is most likeky that the fan bearing is worn and thus causing the rattling sound. You will probably need to replace the fan. Check first that there is no obstacle in the way of the fan rotating.
Replacement of the fan will require the back of the oven to be removed giving access to the fan unit, which will need to have the wires disconnected and the fan assembly unbolted. Fitting is the reverse.
Always remember to switch off the power before working on electrical equipment.
Jan 07, 2010 | GE Ovens
Freezer fan stopped working, water & ice dispenser stopped workin
these fan motors are usually good for 12-15 years, but occasionally one goes bad prematurely. IT NEEDS TO BE REPLACED. Some people try to reoil the bearings, but this is temporary and not worth the effort. The ice maker not working is only a consequence of the cold not being distributed by the fan not working. There are generic replacements that usually work well and cost $30 or less, whereas the GE replacement may cost $50-80.
Dec 27, 2009 | GE GSH25JFR Side by Side Refrigerator
New evaporator fan not running smoothly
Great ! ! Usually the main control board is the problem , when the evap fan doesn't run .
Sep 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a 2002 GE side by side the freezer works fine but the refrig side is not keeping cool enough.....Any help please.
your condensing fan in the unit may be out. This fan supplies the cold air from the freezer to the fridge. To find it look at where the temp control switch is in the fridge. There should be some vents in this area. The fan is located behind that panel. Once you remove the panel take the model number and serial number to the parts house and they should be able to get your fan part. If by chance the fan is rotating then it is possible your defroster is out. You will be able to tell if the defroster is out there will be a large chunk of ice in the area of the fan
Jul 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Condenser coil fan not runningon GE pds22scrrss
The fan can rotates freely even if there's no power to it(fan probably burn out).You can check if power is going to the fan motor by folowing the two wires fron the motor picking up power from the compresor connections under a black plastic cover on the side of the compresor.If you nave power going to the fan its needs to be replaced.
Apr 26, 2009 | GE PDS22SCRRSS Bottom Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
41 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
