Question about Gaggia Titanium Espresso Machine
The close door message stays on my Gagia Titanium coffee machine even when the door is closed. I have tried reloading the factory settings but even this does not help
  • 1,089 Answers
HI
There are 2 things that give the close door message. On the back side of the door towards the hinge, there is a pointer that activates a switch. If that pointer is broken, it won't touch the switch. Replace the door or modify the pointer to touch the switch. If the pointer is not broken, there is an adjustment inside the machine on the steam manifold mount that has 2 screws that can be loosened to move the mount forward (bringing the switch forward) so the pointer can touch the switch.
Posted on Jul 01, 2009
My machine is stuck. The LCD reads Rinsing Cycle, Close door
IT LOOKS THAT THE COMPUTER IS TELLING YOU TO CLOSE THE DOOR FERST BEHIND THAT DOOR MAY BE A MICRO SWITCH WICH IS NOT DOING WHAT ITS SUPPOSE TO DO
TRY TO OPEN AND CLOSE MAY BE YOU HAVE TO BE ALITTLE HURDER THEN NORMAL AS THE SWICH MAY BE WEAK. TRY THIS FERST
Mar 03, 2016 | Gaggia Titanium Espresso Machine
The brew unit does not line up with the nerled spindle gagia says the gear box has sliped
Be for you send if off take a look at you-tube. type in stuck brew unit and one of the videos walks you through this problem.
Aug 11, 2011 | Gaggia Titanium Espresso Machine
After decalcifying our Gaggia coffee machine and it going through its rinse the messages says rinse finished close knob. The knob is closed but the message stays and the machine cannot be used as its...
A frequent problem with some of these is that the internal switch loosens up. It is a micro switch positioned so that the steam knob contacts the switch when you close the knob fully. You can try pressing in on the knob while you turn it closed and that will usually cause it to contact the switch and get you going again.
It will likely happen again and if it does you may want to open up the machine (if you are very handy with that sort of thing) and get the switch securely positioned so the steam knob closes it reliably.
Dec 13, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium that continues to Steam.
You need a new valve. Try getting the stainless steel valve assembly.
May 03, 2010 | Gaggia Titanium Espresso Machine
Ventilate message, then no steam coming out
Sounds like you have an internal blockage in one of the boilers.
Take it to your local service agent for repair.
Did you remove the milk frother and try the hot water again?
A blocked frother is a very common problem .
Feb 24, 2010 | Gaggia Titanium Espresso Machine
Can't get rid of ventilate message on titanium plus machine
Try this, after opening hot water valve, push the knob in when it asks for ventilate. If that works then contact your nearest gaggia distrubutor and ask for a new stainless steel steam valve assembly.
Jul 04, 2009 | Gaggia Titanium Espresso Machine
Close door read out appears
You have a problem with the door alignment and the door switch.. The slightest movement triggers the door switch. You should have someone look at what is causing this issue.
For service on your saeco espresso machine in the New York area: www.cerinicoffee.com
May 24, 2008 | Saeco Incanto Classic Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
434 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
