Question about Hunter Ceiling Fan Remote Receiver 85112-01
Our Hunter fan speed controller is not working. When we press high, it goes on high speed. When we press medium, it goes off. When we press low, it goes on high speed. When we press off, it goes off. Can you help?
    Problem Solver:
Hunter's remote systems are notorious for failures. We replaced ours before the fan was one year old, and then it did it again within a year after that. The warranty, of course was on the ORIGINAL part, not the new part, so Hunter will never help you out, even though their remote receivers (the part in the fan) are junk!
Posted on Jul 26, 2009
  • 34 Answers
Buy a remote control from different company.
Posted on Jul 08, 2010
    Sergeant:
    Champion:
  • 235 Answers
It is either wired incorrectly or the switch needs replacement.
Posted on Jun 30, 2009
5 Suggested Answers
hardrocko
  • 1476 Answers
SOURCE: 3 speed Hunter Fan only has 2 speeds
Assuming that the unit was wired properly from the factory and without being able to look at the switch I would have to agree that the switch is bad. The different speeds are obtained by having a different winding for each speed. If the unit was wired properly at the factory and never had three different speeds then the switch is not rotating between all the contacts. The switch should only be a couple of dollars and would certainly be a cheap solution to try. You can check the existing switch by removing it from the circuit completely and checking the continuity with a DMM from the input to each output as you switch it. Continuity should move from one to two to three. If not the switch is bad. If the switch checks out OK then you have a bad winding in the fan and probably need a new unit. Good luck.
Posted on Jul 12, 2006
SOURCE: Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Posted on Apr 22, 2009
SOURCE: hunter speed control problem
I have the exact same problem. Called Hunter's tech support and they confirmed the capacitor must be bad. This is the black box that has 4 wires going to the switch. They are sending me a new one for under $12. I haven't received it yet, but the wires from it going to the switch can be removed from the switch by shoving a paper clip along side the wire, this'll release the spring clip holding the wire in. Not sure, but I may have to cut and wire nut any wires that go elsewhere.
I recommend you call them too and as long as you have the 5 digit model number (usually on top of fan) they should be able to get you what you need.
P.S. it is highly unlikely that it is in the switch. I tried replacing it with one from Home Depot and I actually got Low-Off-High, which is worse. The Hunter tech support guy said you can't use after market switches with their fans.
Posted on Jun 19, 2009
smartr10U
  • 1305 Answers
SOURCE: Our hunter fan won't work on high speed any
Sounds like the variable speed switch may be worn out.
You should be able to purchase replacement switch at the local home depot- type store in the electrical supplies.
Trying to get an exact match to replace may be a bit difficult, but a similar 3 speed switch should work just fine.
Posted on Jul 18, 2010
Fan only runs on slow speed
The receiver in the fan housing may have failed.
Apr 20, 2017 | Hunter Dryers
HUNTER FAN PART # 85095-1
Either need new transmitter or receiver or both. Call 1-888-830-1326 to order parts.
Jan 07, 2013 | Hunter (25417) Ceiling Fan
Our hunter fan won't work on high speed any longer, low and medium speed work fine, when clicked on high - it only goes at medium
Jul 18, 2010 | Hunter Ceiling Fan Control Switch
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
My Hunter fan will only switch from high to low speed and won't
if the three speed switch is functioning the middle speed winding is bad.  Either replace the fan or hook up a wall speed control and keep the fan on high.
Mar 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
Dryers Logo
1,831 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
