Question about Optima Lighting Hardware & Accessories
AC blinks The AC blinks. I am getting power to the adapter?
2 Suggested Answers
mosesclive
  • 191 Answers
SOURCE: blank screen, and blinking Power On light
My friend you need to replace the adapter as the adapter has gone bad and the battery is not charged so u need the adapter to be replace asap. thats for sure.
Regards
Moses
Posted on Jan 17, 2008
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
When ac adapter is plugged in, only AC led blinks green, (no batt, no ram, no HDD) and after pusshing the power button several times, power led blinks greeen for a split second, and the computer never...
Try using another ac adapter, sounds like the adapter is failing. You can either ask if one of your friends has the adapter with the same connector and voltage (check that the wattage of the adapter is sufficient) or if someone has a universal ac/dc adapter for the test. If the laptop starts normally wiht another adapter, then get a replacement adapter and you are good to go.
Oct 10, 2013 | Toshiba Satellite L455D-S5976 Notebook
My laptop will not turn on
Try another AC Adapter with the battery taken out of the laptop. If the light still blinks then that means the motherboard is bad and would need to be replaced.
Jun 01, 2010 | Compaq Evo N1020V PC Notebook
Averatec 3120V - AC adapter light blinking, no charging
get another ac adapter or check if the power dc jack is loose.
Apr 01, 2010 | Averatec 3120V Notebook
Hi! When I press power button, the front LED battery blinking for 5-6 times, then no longer happen. If I remove the battery pack, no one LED blink, no one LED light, nothing happens. The output voltage of...
Your battery pack is not charging. By removing the battery pack and trying to run on AC only you have proved the AC adapter is either not working or the power is not getting through to the laptop.
The best way to sort this is to try another adapter and see if the laptop works, if it does then your adapter is broken (this is possible even though it reads 19.1 under no load.)
If the laptop still does not work with another adapter then the laptop itself will heed repair.
Oct 31, 2009 | Acer Aspire 1640Z Notebook
Laptop battery not charging wanna know how to run without battery
The problem you described here shows that, the case is not likely to be a battery problem, but the laptop AC-Adapter (Charger) problem, because, the red light you are seeing shows that your battery has rundown, and even when you plug-in the adapter to AC, it still blinks red, showing that the AC-Power is not charging it. I would suggest that you get another Laptop AC-Adapter (The Charger), or try it with a friend's own first, then you'll see that the problem might not be with your battery but your AC-Adapter
Jul 09, 2009 | ASUS Computers & Internet
No power to monitors, but blinking led on ac adapters.
Hi...there,
Try replaced with a new AC Adapter. If it still the same...then you got a busted backlight inverter. To order a new AC Adapter go to this site @ www.3rd-rocks.com click on lcd parts. have a nice day!
Feb 23, 2009 | ViewEra Computers & Internet
Removing battery
If there is a CMOS battery it should be replaced but it could the AC adapter might need to be replaced.
Jul 20, 2008 | Computers & Internet
Blank screen, and blinking Power On light
Regards
Moses
Jan 17, 2008 | Toshiba Satellite Pro 6100 Notebook
Hardware & Accessories Logo
210 people viewed this question
Top Optima Lighting Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you an Optima Lighting Hardware and Accessory Expert? Answer questions, earn points and help others
