Question about ASUS P5LD2-VM Motherboard
Need drivers for PC Chips MB M848A
Cant find SATA drivers for the PC Chips M848a MB. Any way around this problem. Any help is appreciated.
  • frank621 Jul 01, 2009
    Thanks for the reply. I found out a little while ago just what you said. I have ordered a PCI SATA card , hopefully that will work.
    again thank you.
    Frank
    President:
  • 2,678 Answers
The MB you mention does not support SATA it has noSATA connectors
Posted on Jul 01, 2009
Instruction manual for an
Go to the PC Chips website (As we all do) to find a manual in the support section.
Apr 29, 2013 | PC Chips M848A V5.0 Socket A and FSB400...
Update for SiS 2615 Display Adapter to load windows XP pro
The PC Chips MB PCCHIPS SiS746FX M848A V5.0 462 motherboard does not have onboard video, correct? So if you can obtain the make and model of your video card, you can then find the Windows XP drivers online for download. Then you would be able to provide said drivers when the "system asks you to update SiS 2615 Display Adapter driver"
*Another quick fix would be to use a different VGA card, if you have one available?
*Now, I have never been prompted to update display driver before or during a windows installation or update. So that step I would require a little more detail on. I have only been prompted for mass storage drivers (as seen in screenshot).
Apr 19, 2010 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
I need a wiring diagram fora M848A motherboard
Hey compu_suppor,
Good Luck finding a schmatic of the board. I'd contact PCChips directly and see if they even published one. HERE's a least the manual wih their info you contact them.
Good Luck
Mark
Oct 17, 2009 | PC Chips M848ALU Motherboard
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Hi i have a problem with panel1 on M848A v5.0 motherboard i cnt seem to work out how to connect the case properly it looks like this ()()()() ()()()()() i have the power switch, reset switch, hdd led and...
OK, this is for all the idiots who reply and offer NOTHING. You need more info, model and ver? HE ALREADY GAVE ALL THAT INFO.
Type "M848A v5" in google and you will see it is a PCChips mobo AND the manual is here:
http://download.ecsusa.com/dlfilepcc/manual/848Av50.pdf
BUT the manual DOES NOT HAVE THE PIN-OUT, so the manual is worthless...
Here is the pin-out:
(2)(4)(6)(8)
(1)(3)(5)(7)(9)
...and thanks to guntotenmadm
Aug 28, 2009 - The pin layout on the MB are color coded. There is green, orange, pink, and blue. I'll start with the green pins 2 and 4 these are for the power led wires, bottom pin #2 is the + pin (your green wire). Pin #4 is - (your white wire). Now the orange pins, pins 1 and 3 these are for the HDD led. The bottom pin #1 is the HDD + pin (your red wire). Pin #3 is the HDD - (your white wire). Now the pink pins, 6 and 8 these are for the power switch. Pin #6 is the + pin (your orange wire). Pin #8 is the - pin (your white wire). Now the blue pins, 5 and 7 these are for the reset switch. Pin #5 is the - (your white wire). Pin #7 is the + (your blue wire)."""
May 18, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Cmos clock will not set !
Is the cmos clear jumper in the wrong position? if it is it will drain the battery and mess up the clock, You may have to flash the eeprom with a newer version BIOS obtainable from the manufacturer, check their website on this to see if it is a known issue ( I have seen this on multiple other manufacturers main boards). If this isnt it it is possible you have a bad clock chip
Dec 31, 2008 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
PC Chips M848A Motherboard
Try clearing the bios/cmos using the jumper on the board, page 10 in you're manual. Than try booting. See if you're keyboard allows you to get into the bios/cmos. I'm guessing you tried another keyboard? You can also buy a PS2 - to -USB Y adapter. This is what one looks like.
http://www.cablestogo.com/product.asp?cat%5fid=104&sku=27225
If you bought an AGP graphics card lately you might have also received a single PS2 to USB adapter free. Like this one.
http://www.cablestogo.com/product.asp?cat%5fid=104&sku=35700
It's not uncommon for the the lights to function & yet the keyboard not function. A single pin within the PS2 on the keyboard could be bent or bad or not seating correctly in you're new board.
Mike
May 31, 2008 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Jack call-outs and drivers
http://www.pcchips.com.tw/PCCWeb/Products/ProductsDetail.aspx?MenuID=24&LanID=0&DetailID=251
hope that fixes it for you :)
Jan 06, 2008 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
ASUS P5LD2-VM Motherboard Logo
573 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
