Question about Tappan TGF657 Gas Kitchen Range
I have a series 30 Tappan Gas Range with a broiler pilot light that glows but does not light.
  • 999 Answers
Either a weak ignitor or stuck valve. I tap on the valve with the plastic end of a screwdriver while it is glowing and if it lights the ignitor is weak. If not the valve is stuck and both should be replaced.
eric
Posted on Jul 01, 2009
TAPPAN GAS RANGE MODEL NUMBER MPF500PBWD
the owners manual will not give you any repair info. Only use instructions. Your model has an oven safety gas valve that opens only after the secondary pilot heats the end of capillary properly. You may need to clean/replace the pilot assembly OR replace the oven safety valve. If you need the valve, look on ebay because these things are over $275 from Tappan.
Aug 21, 2014 | Tappan MGF500PBW Gas Kitchen Range
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
The stovetop of my Tappan series 110 works, but the oven won't. What do I do?
if the oven wont fire up, 90% chance you have a glow rod failure, this is like a pilot lite
call a local service company.
Please Rate/Vote this response. Thanks
Dec 20, 2010 | Tappan MPF500PBW Gas Kitchen Range
Self light oven not lighting - gas fills the room
its the hot surface igntior that glows could be cracked might need replacing
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
Our tappan oven won't light. the pilot element lites and glows but no gas to the burner
Either the safety valve is stuck or the ignitor is weak. While the ignitor is glowing. use the handle of a large screwdriver to tap on the valve body. If it lights replace the ignitor. If it does not light replace both the ignitor and the safety valve.
Eric
Nov 08, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
Where is the pilot light for the oven?
Look inside the oven where the burners come into the oven. Right at that point you should find the pilot light. Here is where you light the pilot.If you smell a lot of gas when you open the door, turn off the gas altogether and let it dissipate. Then turn ot on and then you can light it.
Jan 30, 2009 | Tappan TGF320 Gas Kitchen Range
Oven won't heat
try replacing the oven igniter/ glow bar the thing you see light up it sounds like it is weak you can tell if it glows with a white color in the bar it should glow a bright orange color
Aug 28, 2007 | Tappan TGFS_63 Gas Kitchen Range
Tappan TGF657 Gas Kitchen Range Logo
405 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
