Question about HP Pavillion ZV6000 Notebook
I have a hp dv2000nr laptop that won't boot. Turn the powre on and all the lights turn on but a blank screen with no beeps.I can here the CD rom moving for a moment but then stops.I tried an external monitor and same problem. I tried removing the battery and power cord holding the power in switch for some time and same problem.I am at a lost thinking the MB need to be changed.No post and cannot get into the bios.
  • HP Master
  • 32,281 Answers
You could have RAM problems.
Reseat the RAM module/s, they may not be making proper connection. If this doen't work you may have faulty RAM. Take them out and test them in another laptop or get your friendly computer shop to test them for you.
Posted on Jul 01, 2009
Laptop hp cq62 not start, black screen. after pluging ac cord he start itself, and after that, it is impossible turn it of.
You can generally only flash a bios if you can get the machine to boot up into some operating system. Do you get ANY on-screen logos or messages when you apply power to the laptop? Can you get into the bios when you power up the laptop and press Esc (or F2 depending on your model)? Do you hear any sequence of 'beeps' when you power up the laptop? A series of short/long beeps when powering up indicates some kind of error detected by the Power On Self Test (POST) routine. Do you have the HP recovery CD for your laptop? Have you put it in your CD Rom drive and tried to boot up? Check the manual at HP Support for a hard reset procedure- you could have a bad power button board or other hardware problem-it is not usually a BIOS problem.
Jan 28, 2015 | HP Computers & Internet
Cd rom boot
Follow the steps below to configure the boot order on most computers.
  1. Turn on or restart the computer.
  2. While the display is blank, press the f10 key to enter the BIOS settings menu.
    NOTE: The BIOS settings menu is accessible by pressing the f2 or the f6 key on some computers.
  3. Select the Advanced tab using the right and left arrow keys.
  4. Use the up and down arrow keys to select Boot Order .
  5. Follow the on-screen instructions to change the boot order.
Nov 06, 2013 | HP EliteBook 6930p Notebook PC
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
HP Compaq 6735s Laptop screen was blank when turned on
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Mar 26, 2012 | Computers & Internet
My HP Pavillion does not boot up. there is a blank screen with blinking cursor. When I press F2 it asks for a driver disc that I do not have.
Is it saying booting from disk?
Try to turn off your computer for about 5 mins. Once you turn on the computer, you will hear it beep. Just after the beep, press f8 and select your hard drive so that you can boot from it.
Sep 16, 2010 | HP Computers & Internet
HP nx7010 - Blank Screen - wont load.
This looks like it can't recognize the hard disk or it's empty - no OS. To check that it's not a hardware fault just boot from a Linux Live-CD like http://pclinuxos.com/
If the hard disk is there and with all the data apparently intact then most likely the MBR was corrupted, fix it.
Jan 13, 2010 | HP Compaq nx7010 Notebook
My friends computer just stopped working while she was using it. The screen froze and than she shut it down. When she tried to turn it back on all that happened was that the caps lock, the scroll, and the...
There are a number of things that can cause this to happen. Try taking the battery out of the notebook, disconnect the AC adaptor (if in use) press the power button a few times. Re-install the battery, reconnect the AC (if needed), press and hold the power button for about 2 seconds. This is a hard reboot and should correct you issue. When the notebook powers up, make sure you remove any cd's in the cd-rom drive.
Good Luck,
C2Solutions
Jan 05, 2010 | HP Compaq Presario V2000 Notebook
My BOSS HP tx2000 will not turn on WHILE...
ok Do you hear any soun when your system try to boot?like a beep sound ?
try this remove battert remove the ac adaptor from the noatbookand press and hold the power button for 10 sec and connec the ac adapter not the battery and turn on the noatbook and at the HP logo hit the F 10 key for 2 times and you will be on bios screen hit the F9 ket and restore the setting to default and hit F10 agian to save and exit and allow it to boot it thats work try with battery connected
Regard!
Sep 16, 2009 | HP Pavilion TX2000Z Notebook
HP PAVILION DV2000 boot problem
Your could not be booting for several reasons anything from faulty RAM to software issues. Since you cannot boot to any type of working screen you will need to use the operating disc with XP or Vista on it. Put it in the CD-ROM and reboot. Let it run for a while and it will eventually ask you to install or repair. I would try repair first as if you install then you will lose all of your data, docs, favorites, pic, etc. if you have any questions let me know.
Feb 19, 2009 | HP Pavilion dv6000z Notebook
My Hp Pavilion dv4000 screen stays blank
have you got a bootable cd or recovery cd , boot from it and do a fresh installation, i think your windows has got corrupt
Nov 05, 2008 | HP Pavilion dv4000 Notebook
HP Pavillion ZV6000 Notebook Logo
137 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
