Question about Toshiba Satelite® A105-S4244 PC Notebook
The right mouse key on pad is loose and becoming harder to use. would like to remove, clean and hopefully fix toshiba model A135
Mouse pad doesn't work
On the laptops keyboard you should find that one of the F Keys (ie F3) will have a picture that looks like to touchpad on it. If you press and hold the blue FN key in the lower left of the keyboard and then the F Key that might restart it working again. Good Luck
Rytech Computer Services Limited.
Oct 11, 2010 | Toshiba Satellite A135-S4527 Notebook
My keyboard and touchpad cursor are both frozen.
Touch Pad can be disabled on two different ways. The first one is using FN+F9 key combination or using DISABLE option in mouse properties in control panel
Mar 18, 2010 | Toshiba Satellite A135-S2246 Notebook
Mouse pad cursor doesn't work
try using the FN key with the monitor/VGA output selection changer(usually F5). You will see a little icon that looks like two monitors. Mouse control may have been changed to the external monitor connection. See if pressing FN(function) and holding that key and then pressing the monitor key will bring back your mouse indicator. You may need to do it with the projector connected and on.
Sep 12, 2009 | Toshiba Satellite A135-S4527 Notebook
The mouse touch pad doesn't work
Fn+F9 is the hot key for enabling or disabling the touchpad
Aug 20, 2009 | Toshiba Satellite A135-S4527 Notebook
Touch pad refuses to work
Try going to Toshiba's support page and re-install the driver for the touchpad. If this does not work. You may need to replace the touchpad itself.
Apr 16, 2009 | Toshiba Satellite A135-S2386 Notebook
Touch pad disabling
Click Start->(Settings) Control Panel->(Classic View) Mouse, then click Devices tab and disable it:
Apr 03, 2009 | Toshiba Satellite A135-S2246 Notebook
Mouse Pad not scrolling
you may be able to fix this by going to control panel and then mouse settings
you also may want to check your driver by right clicking my computer properties hardware then device scroll down till you find your mouse thrn right click and update driver
Jan 16, 2009 | Toshiba Satellite A135-S4527 Notebook
Touch pad not working properly
Plug in a usb mouse and go to control panel>system>hardware>device Manager (if using XP) or control panel>system>device manager (if using vista) and right click on pointing devices, unistall the touch pad and reboot - remove the usb mouse and the touchpad will be installed again as new hardware. I hope this helps
Nov 28, 2008 | Toshiba Satellite A135-S2276 Notebook
Mouse pad is not working
hi
can u enabling the touchpad by pressing Fn+F9,Fn+F7,.
Mar 16, 2008 | Toshiba Satellite A135-S4527 Notebook
Frozen mouse with a touch pad laptop computer
Many laptops have a button, usually located right above the touchpad, that disables the touchpad.
And there may be drivers that need to be loaded for some touchpads to operate properly, in case you've reinstalled the OS.
Jan 25, 2008 | Toshiba Satellite M35X-S161 Notebook
Toshiba Satelite® A105-S4244  PC Notebook Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
