Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Can't get paddle attachment on my mixer.
I can't get the paddle or whisk attachment onto my kitchenaid mixer. It appears as though the button on the machine is stuck. I already tried wrapping the button apparatus with a steaming hot, wet cloth (I did it twice for 30 minutes total), and I sprayed the button with cooking spray. Neither attempt worked.
4 Suggested Answers
SOURCE: Paddle Scraping - KitchenAid Professional 600
There is an adjustment screw and a system for setting it. You can find a video of it here (or just a ton of people who know all about these mixers). I just found it while trying to troubleshoot the same problem for my wifes mixer.
http://forum.kitchenaid.com/forums/forum.asp?FORUM_ID=196
Posted on Nov 02, 2007
  • 10865 Answers
SOURCE: I cannot remove the attachment on the kitchenaid
Hello. I can assist you. I also have this mixer and I can tell you from experience. You have to lift it up about 1/4 inch and then twist it a small amount and pull it down and out. You can not hurt it so don't worry about using some force when you do this. Good luck with it.
Posted on Nov 16, 2009
  • 5 Answers
SOURCE: Brand New Kitchenaid Artisan Mixer - Mixer head is stuck
Unplug the mixer, turn the whisk the opposite of normal rotation in a quick motion, the remove a per normal.
Posted on Feb 20, 2010
The beater to bowl screw is locked in position and cannot be adjusted. flat beater and whisk hit bottom
Without looking at it myself I can' think what the problem would be but a cheating solution would be to undo the 4 screws that hold the pedestal to the motor housing and put 4 washers there between the pedestal and motor housing and replace the screws.I assume you mean the flat paddle beater because that's the only one to use to set the bowl height.
Dec 02, 2015 | KitchenAid KSM50PR Professional Series...
Kitchenaid whisk will no longer slip past the locking pin to rotate and attach on the spindle.
this might help... the whisk has a slightly larger whole then the other attachments. it is also inset. there is a washer that holds the spring on. if that is slightly off or bent it won't sit in the Whisks inset right. look a little closer to that and the spring. if there happened to be dried on food that could be the slight difference that can prevent it from staying one. Hope this helps!!!
25298509-2el2bftwapqh2uesegcwr3xp-2-0.jpg 25298509-2el2bftwapqh2uesegcwr3xp-2-1.jpg
Nov 27, 2014 | KitchenAid Professional 620 6-quart...
Head does not lock but when adjusted whisk touches bowl
The screw is purely for adjusting the head height and that is with the flat paddle. If the head is not locking when the paddle is at the correct height then the locking mechanism needs to be adjusted. If you take it to a Kitchen Aid authorised service person they will sort it for you, they will have done heaps of them. Often the solution is with a file, if you go too far there is no going back so best left to the experts.
Jan 21, 2014 | KitchenAid Artisan Stand Mixer KSM150PS -...
I purchased a new KitchenAid Professional 600 Stand Mixer Model #KP26M1XQNP. I used it once and it was difficult to keep the paddle from coming off during mixing. The speed didn't seem accurate...
Stop messing about with it and return it to place of purchase to be fixed under guarantee. Any fiddling about you do with it is only going to endanger your guarantee.
Mar 29, 2017 | KitchenAid KP26M1X Stand Mixer
Mixer will not turn on. Is there a reset button?
There is no reset button. More than likely the speed control plate is bad. This is a common problem. I recommend storing the mixer unplugged and on the first speed. Also don't store it with the beater, whisk, or hook attached to the mixer. This may help save the control plate contacts from becoming sprung. Fixmymixer@aol.com
Feb 19, 2011 | KitchenAid K45SS Classic Stand Mixer
There was no manuals in the box. I would like to download one free.
what do you need a manual for, just throw your stuff in there and mix it, the hook is for bread dough. the white paddle is for like potatoes, the whisk is for eggs, just dont put the stainless steel bowl in the dishwasher, wash it by hand
Oct 22, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Whisk attachment is stuck on mixer.
I took a small crowbar, and put the curved end up inside the whisk, and hammered the other end lightly. After about 20 taps, the peg was lined up with the sideways opening so I could twist it off. When I got it off, it looked like there was either flour inside the part where the whisk attaches, or some light corrosion was going on. Either way, I'm going to put a little grease in there so it doesn't happen again.
Mar 09, 2010 | Food Mixers
Feb 19, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Whisk is stuck..can't be removed. what can i do? mixer is kitchen aid c 4. thanks for any suggestions!!
We had this same issue with our KitchenAid Mixer. Whether it is the whisk attachment or the paddle, the problem is that stuff (most likely sugar based) got into the attachment connection area and dried. It seems like a little sugar couldn't possibly glue the attachments to the stand mixer, but it does.
The solution is to turn the mixer on it's side and pour a kettle or two of boiling water on the section that joins the mixer to the attachments. Pour slowly to allow boiling water to penetrate grooves. Wiggle a little, pour more water, repeat... that should allow you to get it off.
In the future make sure to soak the attachments in boiling water every once and a while to allow all the gook to loose. And let it fully dry before reattaching to mixer.
Jul 13, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
194 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
