Question about Nintendo DS Lite Console
My son's ds is giving us the error message that there is no disc inserted, when there actually is. Have cleaned all discs. It gives us this error message with every disc. Thanks!
    Filmmaker:
    Uploaded 5 video answers.
  • 182 Answers
U NEED TO REPLACE UR NDS CART READER HERE IS ALINK WERE U CAN GO BUY IT AT
http://www.dealextreme.com/details.dx/sku.21906
Posted on Jun 30, 2009
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    When we insert game discs in our wii, it will let us play for about 2 minutes, then give us a message that reads, "disc cannot be read, please refer to wii ooperations manual." I ordered the wii...
    Check to see if there are any scratches on the disc. Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating "Disc Read Error" or something to that effect. With some scratched discs, the data cannot be read and the game console may not even recognize the discs at all, giving you error messages etc. Best remedy for starters, is to try clean the discs and make sure there are no smudges or dirt marks left on the play-side of the discs. If there are any scratches on the discs, they will need repairing.
    Most Game Discs, DVD's and CD's can be fixed quite easily back to "As Good As New Condition". Some home remedies or cheap repair kits may help with some light marks or very light scratches on some discs, but a professional disc repair service is usually required to repair any discs with anything more than very light scratches.
    For further help on disc repairs, visit:
    www.discREPAIR.ie Get Scratched Discs Repaired Back to "As Good As New Condition".
    Check the "More Info" & "FAQ" Sections for further details on game disc repairs and related matters.
    If you tried some home remedies and they have not worked, try sending the disc off for repair. Contact the site above for advice on repair and shipping.
    Hope this Helps!!!
    Dec 06, 2010 | Nintendo Wii Console
    Ds lite saying no ds card and no game pak inserted
    Defecttive Slot 1
    Look inside with a litte light. You will almost certainly see bend pins. You son has almost certain play with someting sharp inside the connector.
    Slot1 must be replaced
    Apr 21, 2009 | Nintendo DS Lite
    Cannot read disc
    If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide...
    Mar 29, 2009 | Nintendo Wii Console
    Unable to read disc.
    If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide,that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
    Feb 02, 2009 | Nintendo Wii Console
    Unable to read disk
    Fiend your solution direct from nintendo. Here is your solution....
    http://www.nintendo.com/wiiconsole/prob676ijt65/solution
    139
    Dec 16, 2008 | Nintendo Wii Console
    Cannot read disc
    Greetings,
    I had the same problem with my Wii. Unfortunatly nothing worked to fix the problem so I called Nintendo's customer services. They were able to replace the unit free of charge. I would simply give them a call: 1-800-255-3700 and press 2.
    Good Luck,
    -WN
    Jun 05, 2008 | Nintendo Wii Console
    Rpd 552 cd reader problem
    Message Possible cause Recommended action
    E-01 Dirty disc. Clean the disc.
    Scratched disc. Replace the disc.
    Up-side-down. Check the disc.
    E-02 Focus error. Try ejecting and re-inserting
    under normal temperature
    conditions.
    E-03 Data and focus error. Under normal temperature
    conditions, eject and
    insert clean, undamaged
    disc properly.
    E-04 Mechanical problem. Eject and re-insert.
    Oct 17, 2007 | Blaupunkt RPD 552 CD Player
    Nintendo DS Lite Console Logo
    89 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
