Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. I can't say it's 100% the problem because I can't actually look at the tv over the internet. If by chance the TV is still under warranty, go that route. If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you the flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
Is it possible to replace a broken screen on a plasma tv? Would you reccommend that I go to a glass...
(More)
Is it possible to replace a broken screen on a plasma tv? Would you reccommend that I go to a glass specialist to have the glass cut, then my handy dandy hubby can install it?
I have a year old 52" Philips LCD 1080P tv. In the past month the tv will intermittently go...
(More)
I have a year old 52" Philips LCD 1080P tv. In the past month the tv will intermittently go into an error state. I try to turn it on. The blue LED illuminates for a few seconds, then it reverts to the blinking red error code (6 long blinks, 3 quick blinks). Do you know what this error code indicates? In the past (4 times prior) I have unplugged the tv and within 24 hours it recovers. This happened again last night. Tried it this morning and this time it didn't recover.
does anyone have a copy of the service manual for a sony kdf-e55a20 ?, i only need the pages...
(More)
does anyone have a copy of the service manual for a sony kdf-e55a20 ?, i only need the pages refering to replacing the thermal fuse
