Question about Dell desktop and monitor -Inspiron 530-Intel?® CoreTM2 Duo Processor E4600
Not detectingice bus controller
Not detecting ice bus controller///after using restore disk
  • Dell Master
  • 1,165 Answers
You have to go to dell download and download the driver
Posted on Jul 01, 2009
Code u2100- u2105
U2100 - GM Type Network - Manufacturer Controlled DTC - Manufacturer Controlled Description CAN Bus Off (4L30-E Transmission) Conditions
Cause Key on and the TCM detected a loss of communication on either Communication Area Network (CAN) Bus line for one second
U2103 - GM Type Network - Manufacturer Controlled DTC - Manufacturer Controlled Description CAN Bus Reset Counter Overrun (4L30-E Transmission)
Cause Key on and then the TCM detected a loss of communication on either CAN Bus line that exceeded 40 time out requirements
U2104 - GM Type Network - Manufacturer Controlled DTC - Manufacturer Controlled Description CAN Bus Reset Counter Overrun (4L30-E Transmission)
U2105 - GM Type Network - Manufacturer Controlled DTC - Manufacturer Controlled Description CAN Bus Error ECM (4L30-E Transmission) Conditions
Cause Key on and the TCM did not receive ECM messages for 1 second
BUT, THERE IS NO FAULT CODES RESULT FOR U2101 AND U2102
or you can ask the 24 hrs live technical support was multi-diag, they will like to help you, good luck
Aug 14, 2013 | 2005 Isuzu Ascender
It is not detected in "My Computer " . It has never been used since I purchased it
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
Windows 7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
if you need more help with this post a reply
hope this helps
Sep 23, 2012 | Kingston 16GB DataTraveler 101 Generation...
Ricoh aficio 3035/3045 error sc 672 not able to proceed to service mode also, kindly help me pls.
possible a bad operation panel replace or 672 B
After powering on the machine, the
communication circuit between the
controller and the operation panel is not
opened, or communication with
controller is interrupted after a normal
startup.
Controller stall
Controller board installed incorrectly
Controller board defective
Operation panel connector loose or
defective
690 A GAVD block I2C bus error
An error is detected in the GAVD
communication I2C control register of
the GABIC2.
I2C bus on BICU defective
691 A GAVD FCI block I2C bus error
An error is detected in the FCI
the GABIC2.
692 A CDIC GAVD block I2C bus error
An error is detected in the CDIC
the GABIC2.
700 B ARDF original pick-up malfunction
After the
Sep 21, 2012 | Ricoh Aficio 3045, 3035 Kit
Card reader is not being detected in my windows 7
hope this helps
Aug 24, 2012 | Electronics - Others
Samsung BD-E8300 HDD not detected
If using windows 7
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Jul 29, 2012 | Samsung BD-E8300 3D Smart Blu-ray Disc...
Need a sm bus controller driver
You can download the sm bus and device drivers from MSI WEB supportsite, select your model motherboard to download :-http://www.msi.com/index.php?func=downloadindex
May 22, 2012 | eMachines T6410 Driver Recovery Restore Cd...
How to restore original windows on a toshiba satellite a105-s4184
I have toshiba laptop satalite with 2 operation windows 2000 and HP windows running thus slowing the system down consiradably. Idealy would like to delete the windows 2000 professinal. Please help
Sep 26, 2011 | Computers & Internet
Fresh install of Win XP onto a Compaq Presario V6000. Now getting SM Bus Controller error.
If you installed a Non HP version of XP you will have problems. Try reinstalling XP using the restore disks provided.
Mar 28, 2011 | HP Computers & Internet
My memory card is not detected by card reader .it says insert disk in drive i:.card is detected and read in nokia phone.
Click the right on my computer and select manage.
In this category select device manager, it will display user areas.
In the last select universal serial bus controllers and click the double on your device.
Select use this device at the bottom of the dialogue box.
Dec 24, 2010 | Kingston 2GB Secure Digital Memory Card
Hello, I have several probs.going @once,in the device mngr.i have several yellow ? marks.for the following.1:)Audio device on Hi Def audio bus. 2:)Ether net controller,3:)sm.bus controller 4;)video...
You probably installed Windows from a "generic" CD-ROM.
Reinstall Windows, from the ACER-modified Windows "System Restore" disk, and all the correct device-drivers will be automatically installed.
Or, find another computer with Internet access, and a CD-writer.
Access ACER's web-site. Click "support" and "download", and download the AUDIO and NETWORK and MOTHERBOARD and VIDEO drivers to a folder on the computer.
Burn the contents of that folder to a CD-recordable.
(Since you say that your 'SM Bus Controller' is not working, you won't be able to use a USB memory-stick on your computer.)
Move the CD-R to your computer, and install the MOTHERBOARD driver, and then the other drivers, from the CD.
Sep 28, 2010 | Acer Aspire 5100-5022 Notebook
Dell desktop and monitor -Inspiron 530-Intel?® CoreTM2 Duo Processor E4600  Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
