Question about Hotpoint FFM90 Bottom Freezer Refrigerator
Fridge sounded like a car revving
Fridge (bosch) was very noisy like it was vibrating, could her it in another room. always been loud. switched off & on again & it stopped working. light on! (nobody home, as the old addage goes!) motor hot! 3 years old!
  • 40 Answers
Check the compressor fixation are okay.Normally it should be on rubber parts fixed to the bottom.If one of them is not fixed it can vibrate.
Posted on Jun 30, 2009
My new black glass double door fridge and freezer is so noisy it actually wakes me up.Please help.Les
Les,
The nature of the noise can tell you a lot. Is it a smooth compressor sound that is excessively loud? Is it metallic like a fan blade might make if it is hitting something? A squeal like a failing bearing might make? Is it constant? Intermittent? Has it always been there?
I assume the fridge, other than noisy, operates correctly and normally.
You can add acoustic foam to reduce the noise (Find "Black Hole" acoustic absorbing foam or similar). If doing this, you cannot impede the airflow to the heat ex-changers or the compressor motor, or you could drastically shorten the life of your appliance.
You should also try and divine where exactly the noise is coming from. Lacking a stethoscope, a 1/4 " wooden dowel, placed against various areas on one end, and the other on the little skin flap of your ear, will safely telegraph mechanical vibration to your ear, allowing you to localize problems. Once you know exactly where the sound is coming from, it may be easier to correct the noise.
Mar 17, 2018 | Refrigerators
When RV is plugged-in a loud humming accures nothing to do with air conditioner. Normal?
A solenoid (magnetic contactor), a motor, or wires can produce chattering sound. I think most likely you hear a solenoid that transfers the RV load from one source to another. A manual transfer switch would be quiet.
Electric alternating current solenoids have laminations that can loosen from each other thru vibration and aging, becoming noisy, and are noramly buzzing when energyzed even when new.
Apr 30, 2015 | Heating & Cooling
Bosch Maxx 5 very loud noisy spin
the spinner to motor coupling is damaged by the wear and tear..please replace it
Aug 24, 2012 | Bosch Washing Machines
Bosch dishwasher noisy vibration
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Jun 06, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Noisy pump in bosch nexxt 500 washer
no its usually not that loud at all contact bosh direct to have them send you a new one or call them if its still warrantied
May 01, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
When doors are opened it stops. Ice is forming unnaturally in the
It sounds like you may have a bad evaporator fan motor or broken blade.
Another cause could be a failed defrost system component. The would cause a build up of ice and frost and the fan blade could be coming in contact with the frost or ice.
The fan stops running when the doors are opened on this model to prevent the circulation of warm air.
Sep 11, 2009 | Bosch Refrigerators
Noisy Fridge !!
is the fridge on a level and solid surface ?? hope this helps regards Jim
May 10, 2009 | Refrigerators
Noisy Bosch dishwasher SHU43C05UC
your main wash motor is faulty it must be replaced.
May 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Open Questions:
See all Hotpoint FFM90 Bottom Freezer Refrigerator Questions
Hotpoint FFM90 Bottom Freezer Refrigerator Logo
442 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
