Where is the switch located? I don't know if it is a short or not. What worries me is the door locks popping open. Not to mention the beeping is driving me nuts.Where is the switch located? I don't know if it is a short or not. What worries me is the door locks popping open. Not to mention the beeping is driving me nuts.
Replace the drivers door switch, it's shorting out. It's on the B-pillar below your door latch, covered in rubber that you can pull off to get access to it. You can take it out, just tie a string to the electrical connector and tape it to the door so you don't loose it. The switches are fairly cheap at the dealership.
There is NO possible electrical cause (within REASON) which would create the problem you describe. I assume you tried the Keyless Entry Remote to DIS-ARM the anti-theft system. If the ALARM system was activated, it will stay activated until it's de-activated by the remote (typical design feature). The best SOLUTION is to take vehicle into Hyundai an have the problem diagnosed.
there is a switch in each door that senses the door is open, it is called the door ajar/courtesy light switch (imagine that), they stick and have this problem, replace it.
If you use your keyfob to lock the doors, it will activate the alarm, and you will need to unlock with the keyfob. If you lock the doors with the lock button on the inside of the door, it should not activate the alarm.
replace the door ajar switch
