Question about Kenmore Washing Machines
Top loading #110.29842990 Outer shell came
Top loading #110.29842990 washer. Outer shell came loose from frame. Don't know how to re-attach it.Thought I would find loose connectors or screws or something lying underneath but found nothing. How does shell attach to frame? There seem to be tabs that line it up, but there are no connectors. Don't know how it was functioning as it was.
  • janthony99m Aug 07, 2009
    Thank you Woodmans77. It all finally slipped together using your guidance. It was knowing that the front lip goes under and the rest goes over that made the diff!
  • 672 Answers
The outer case catches under the frame across the front and there is a tab on either side on the frame near the back these tabs go into a slot in the flange on the bottom of the case. You may need to loosen the control console to do this. 1. Disconnect the power. 2. Remove two screws, one at each top corner on rear of console. 3. Push a putty knife under the front of the console near the corner. You will feel the resistance from a spring steel clip. Push, firmly toward rear of machine. clip will release and console will be loose. Repeat at other front corner of console. 4. make sure outer case is hooked under front of frame. 5. Put case on both tabs(check at rear corners on back of machine to assure that back panel and case corner are in the modling that aligns the two. This is sometimes like a wrestling match. Take your time it can be a test of your patience. It is helpful to see diagrams available at www.sears.com under Parts direct. Find your model number and an exploded view is available. Good luck.
Posted on Jul 01, 2009
Bosch sms63mo8au 12 door latch
Could be the latch that's attached to the top of the outer shell frame has become loose and is out of alignment, so its not able to close properly. Pull the unit out from under the countertop and have a look at whats happening with the latches when you try to close and lock the door. Adjust as need.
Aug 07, 2014 | Bosch Dishwashers
How to remove washer lid to replace lid lock
Remove power to the unit.
Locate the console and remove two phillips head screws. Most
models have them in the front, bottom of the console. In some of the newer models they are located in the back, bottom of the console. Some washers require you to remove two end caps on the console to access the screws.
After you remove the two screws, slide the console slightly forward and then up. The console will then hinge to the back of the washer.
With the console now hinged back, locate the lid switch harness.
Disconnect the harness and check for resistance between the 2 grey wires (outside) on the lid switch connector connected to top of washer. With the lid down the circuit should read no resistance. If the circuit is open(infinite resistance) then the switch needs to be replaced. You can also use a insulated jumper on the lid switch harness to determine if its the switch.
To replace the lid switch you will now have to remove the cabinet. Use a flat head screwdriver to remove the two clips holding the back of the washer to the outer shell of the washer.
Disconnect the lid switch harness(If not still disconnected).
You can now pull the outer shell away from the washer. Do this by
grasping the outer shell (I open the lid and grab it there.) and tilt the shell forward (toward you) and out. The shell is now removed and you can see the tub. Be careful not to bend the outside walls of the shell when removing and setting aside. This will help greatly when reinstalling the shell. Remove the 2 screws attaching switch to cabinet. Remove the screw connecting the ground on the cabinet. Use a flat blade screwdriver to push tabs on lid switch connector block to remove. Finally remove the whole harness from the 2 remaining retainer clips under the cabinet. Install new lid switch harness assembly and reassemble washer.
Apr 09, 2014 | Washing Machines
When the washer runs on final spin cycle I hear a banging sound within the unit. As the spinning increases in speed, the banging is extremely loud and unbearable. What would be the problem?
1 or more springs are broken or fell off.
If it is by chance a 2000 or 2001 Sears front load washer (Electrolux), the outer shell likely failed where the springs attach to keep the outer shell and inner wash tub suspended.
If you remove the lower panel, and look underneath and see one or more springs laying down on the bottom of the cabinet, look around to see if you can spot the end of the spring. Sometimes the ear that breaks off these will still be attached to the spring. The ear cannot be glued. The outer shell "could" be replaced, but the time investment makes complete replacement of washer the only cost effective solution in that situation.
If by chance the springs simply popped out, they can be re-hooked to the ear they came out of with some effort and careful pushing of the outer shell.
Dec 20, 2011 | Washing Machines
Washer shaking, making loud noise and leaking water
Sounds like a tub support could be defective causing excessive tub movement splashing water outside the washer. Try to move the tub by hand and see if it is firm and snaps back to its center position. If the tub is loose, lift the top cover off by using a non marring tool to pry the front up and lift the cover back on the hinges. Inspect the tub supports for broken or worn rubber shock absorbers. Look at both the tub support shafts and the corner stabilizer attached to the frame and the outer tub. You may need to inspect the fill hose and the water injector to see if it is loose or cracked.
Feb 15, 2011 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag washer MAV551EEWW top load with loose tub
If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
May 07, 2009 | Washing Machines
Crack in outer tub of front loading washer
ARear Tub Bearing Replacement
This advice is for replacing the rear wash tub shell of most FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud "rumbling" type noise during the spin cycle, excessively vibrates, or won't spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
DISASSEMBLY:
1. Unplug washer and turn off water supply.
2. Disconnect washer inlet supply lines and remove drain hose from standpipe.
3. Using a shop vac, pull a vacuum on the drain hose to remove all residual water from the drain lines, tub and drain pump. If you do not own a shop vac, remove the lower panel under the door and locate the drain pump. If the drain pump has a clean out trap, lay out some old towels, and open the trap to allow water to drain. If the pump does not have a drain trap, disconnect one of the drain pump hoses.
4. Remove the lower panel under the door (if you haven't done so in the previous step) and remove the washer top and back panels.
5. Disconnect the dispenser hose from the top of the wash tub and disconnect the hose on the side of the tub going to the pressure switch.
6. Remove the hose that leads from the bottom of the wash tub to the drain pump and remove the drain hose that leads to the standpipe.
7. Remove the door bellow (rubber door boot) from the door frame ONLY and push inside the tub. Leave the other end of the door boot attached to the tub shell. If this is a small front loader, the bellow is cemented to the washer door frame. Use a putty knife to slowly peel the rubber from the door facing. If this is a large HE or Duet model, the bellow is held in place by a small hoop spring. It is located in the seam of the bellow along the door frame at the six o'clock position. Pull the spring out and carefully stretch it apart to remove the hoop from the seam. With the hoop removed, the bellow can be pushed inside the wash tub. Remember to remove the bellow from the water inlet tube that leads from the dispenser.
8. Remove the washer support shocks from the wash tub. The large HE model and Duet models are removed by grasping the upper portion of the shock and turning counter-clockwise. The shock will snap loose and can be pushed aside. Leave the lower portion installed in the bottom of the washer. If this is a small front loader, the shocks are held in place by plastic pins. The pins have a locking tab that needs to be compressed while pushing the pin out of the hole. This is NOT any easy task and it will take some effort. HINT: If you use a long socket that fits snugly over the pointed end of the plastic pins, it will compress the locking tab and enable you to use a hammer to carefully tap them free. NOTE: Large HE models and Duets have 4 shocks, while the smaller models may only have 2.
9. Remove the Drive Motor belt by grasping it near the top and pulling towards you while rotating the large pulley. The belt should slip off.
10. Remove the Drive Motor and Motor Control Board. Carefully label all connections, so you know here the go when have to re-install them.
11. Remove the back casing brackets so the entire back of the washer is open.
12. Remove the rear counter weight from the wash tub to minimize some of the weight.
13. This next step may require two persons: With the tub still suspended by the upper support springs, slowly lay the washer all the way on its back while supporting the wash tub. NOTE: Place something under the washer to support the tub shaft as you lay the washer back (i.e., old blankets, cardboard boxes, etc.) Once the washer is lying down, remove the upper support springs and set the cabinet upright. The wash tub should be now free from the washer cabinet.
14. Set the wash tub assembly upright and remove all the screws around the perimeter of the tub shell halves. NOTE: An electric screw driver with socket attachment works wonders and will speed up this process. If the tub is held together with clips, use a screwdriver along the tub edge under each clip and pry up to remove.
15. NOTE: If you plan on reusing the door bellow, use care not to damage any of the rubber. Place some old towels down and lay the wash tub assembly with the front opening face down. Lift the rear shell off the inner wash basket shaft. You can now inspect the spider arm supports of the spin basket. If the supports are cracked or broken, or if the shaft is worn, you will need to replace the spinner basket.
16. Remove the spinner basket assembly and inspect the front tub shell. In most cases the front shell can be reused and will not require replacement. If the inside of the front shell is damaged, however, it will require replacement.
REASSEMBLY:
1. Reassembling the tub shell parts and inner spin basket is self-explanatory. Just make sure you tighten all screws evenly in a crossing pattern as you tighten the tub shells. If the tub is held together with clips, they can be tapped back into place with a hammer. Use the same crossing pattern to ensure the shells are tightened evenly.
2. Lay the assembled tub shell with the opening face up. Make sure you support the spin basket shaft.
3. Lay the washer casing down over top the washer tub shell.
4. Insert the upper shell support springs into the wash tub and support spring brackets.
5. Raise the washer casing to the upright position, making sure the tub does not swing forward into the washer front. Re-install the rear counter-weight and washer back brackets.
6. Re-install the washer support shocks.
7. Re-install the drain line hose.
8. Re-install the Motor Control Unit and Drive Motor.
9. Re-install the Drive Belt pulley and belt. The belt is installed by placing it into the Drive Motor shaft, first. Make sure there is a one-groove gap between the belt and the end of the drive shaft. With your left hand hold the belt on the drive pulley and guide it around as you turn the pulley with your right hand in a clockwise direction. This can take some effort.
10. Re-install the hoses that lead from the bottom of the wash tub to the drain pump, and pressure switch.
11. Re-insert the water inlet tube into the rubber door bellow, ensuring the rubber is seated past the flange on the tube.
12. Pull the door bellow through the door frame opening and reseat it. If this is a small model front loader the door bellow will have to be cemented back in place with appliance door gasket adhesive. If this is a larger model front loader that has a hoop spring to hold the bellow in place, insert as follows:
- Place the hoop into the groove of the door bellow along the facing of the door frame with the spring in the 6 o'clock position.
- With both hands gradually work your way around to the 4 and 8 o'clock positions and stretch the spring apart.
- Push the spring and hoop into the groove.
NOTE: It may require a second person to get the door bellow back in place.
1. Re-install the rubber dispenser hose to the top of the wash tub.
2. Re-install back panel and top panel and hook washer back up to water source. Make sure the drain hose is placed back in the standpipe.
3. Leave the bottom washer panel off and plug unit back in. Test operate and check for leaks. If no leaks are present, re-install bottom panel.
Some other parts that may have to be considered when performing a rear tub shell replacement:
- Rubber Door Bellow
- Spinner Basket (if arm supports are damaged)
- Front Tub Shell (if signs of internal damage)
- Drive Pulley (can sometimes become damaged trying to remove old one)
- Drive Belt (check belt during parts removal for wear)
- Wash Tub Support Shocks (The shocks can sometimes break when trying to remove)
NOTE: 1. If you replace the front tub shell you will need to remove the door bellow and front counter-weights and install them on the new shell. 2. If you replace the spinner basket, some do not come with the wash tub fins. Make sure you remove and re-install the old ones in the new tub if required.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 24, 2009 | Kenmore Washing Machines
Whirlpool Washer model #LSQ9549LW0
you see the way to remove in theses you tube vidoes- easy enough
Oct 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
The top of the washer has loosened from the base. How do I take off the outer shell to fix the problem? It is in the front top of the machine.
Here is a schematic of a base model of your series. More than likely the block drive is loose which is part 17 and should be replaced along with the nut.
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?modelNumber=LSQ9549LQ0&productCategoryId=0153200&brandId=1198&modelName=WASHER - DIRECT DRIVE&diagramPageId=00003&componentDescription=AGITATOR, BASKET AND TUB&documentId=W0207069&backToLink=Return to Sub Components list
Washer GLTF2070DS0
warranty varies by manufacturer some stainless steel baskets had 10 yr warranty but suspect you may need more than just basket outer shell has a bearing in rear that is pressed in only repair is replace rear shell and basket.. 2 men 2 hrs plus outer shell price and labor.. only 1 yr labor and other parts
Jun 21, 2008 | Frigidaire ATF6000ES Front Load Washer
WHIRLPOOL DUET GHW9100 FRONT LOAD
Take the top off the unit,and check the springs..there are 4 on top and 4 on the bottom..make sure they a attached..and tighten
Jan 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
154 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
