Motorola Dch6200 Catv Digital Receiver Logo
A
Anonymous Posted on Aug 12, 2014
Fix ref code s0600
Charter Cable TV
  • Official Brand Answer 3,100 Answers
  • Posted on Aug 14, 2014
Motorola Mobility
Level 0:
Answers
3100
Questions
Helped
684845
Points
13487
Contact Charter support or contact Arris. ARRIS
Mark
Motorola Support
How do I link my blackweb sound bar model BWC18SB001 to my Charter cable remote?
Hey Sarah..
My sound bar automatically connected with the charter remote when I connected the sound bar to the TV with the optical cable.. it cuts the TV (LG) and the sound bar off/on using the charter remote. Sometimes it gets out of sync and I have to use the sound bar remote to cut it on/off.. only once and it starts working again.
How do I program a charter remote to a rca converter box
Charter 1060BC2 and 1062BC3 - Setup
www.urcsupport.com/html.php?page_id=762
SETUP. The Charter 1060BC2 and 1060BC03 Remote Controls are preprogrammed to operate the cable box (converter) provided by your cable system, an RCA TV, a Toshiba DVD player, and a Pioneer audio receiver. To control devices other than the default brands, perform the following steps; otherwise skip this section.
Program the Digital Cable Remote Control
mscharter.custhelp.com/app/.../program-the-digital-cable-remote-control
Dec 10, 2013 - Highlight or write down the codes and device you wish to programbefore moving on to Step 2. On the remote control, press a device key once (i.e., AUX, DVD , AUD, TV or CBL); it will blink once. Then, press and hold SETUP until the selected mode key blinks twice, then release SETUP.
Charter.net Charter Remote Controls - 1060BC2/1060BC3
www.charter.net/.../charter-remote-controls-106...
Charter CommunicationsProgramming Codes: Select the manufacturer of your device from the list. The codes will appear beside the list boxes. Not all manufacturer brands listed may be ...
Charter.net Charter Remote Controls - OCAP-4
What are sceptre tv codes
the 11599 finally worked with my Sceptre TV.
The Charter app had 1159, but did not have the last code. I tried the channel up over 50 times and it never worked. Went back to reading my searches and found it.
Walter and Barbara Bradford calling back with additional info. The cable box is explorer 4250HDC.It is hooked to the TV with 5 cable hookup.Also there is the power wire and the cable that goes to the box...
what are you trying to do? to hook up the tv you can use the cable output from the charter box into cable input into the tv (meaning cable as in coax cable) otherwise you can use the colored ones. red white an yellow are rca jacks but the 5 wire you talking about are prob compondent cables which are red green and blue. connect those to the tv and the other red and white ones are for audio to the tv you may have to set the charter box to select which output you are using and the tv to the right input for the rca it will prob be input 1 for the component it will be component 1
let me know if thats what you needed
1helpful
Charter remote will not change channels--I have put in tv code but still nothing--noting on the remote will work except to power the tv on
You will need to program it to your cable box to change channels. Remember, the channels in your tv are coming from your box, so if the remote can't control the box, you won't be able to change channels. Call charter for help on programming remote to cable box.
1helpful
Need tv remote code for cablevision remote for a vizio tv
If you mean Charter Cable below is a link to there website. Not knowing which remote you have I couldnt post all of them on here.
Click the link below then choose ( Equipment, User Guides & Diagrams) scroll down and you will see 5 remotes. Choose the one thats yours and open the user guide. It will give you the codes and also instructions on how to enter them. In case Vizio isnt listed it will also give you instructions on how to do a TV code search.
http://www.myaccount.charter.com/customers/support.aspx?menuitem=2
If you dont have charter please post again with who your cable service is with and we can help you further.. Good Luck!!!!
STUMPED
KUJO,
This should help... Charter doesn't make a remote and millenium 4 is like saying cotton swab, which doesn't tell me who actually makes it like Q'Tip... But this should get you in the right direction. http://www.remotecodelist.com/remotes/
Bill
Top Motorola Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Motorola Audio Player and Recorder Expert? Answer questions, earn points and help others
