Question about HP Pavilion dv9000z Notebook
I own a HP DV9000 my wireless quit working
I own a HP DV9000 Laptop Computer with a 17" monitor. . Well today when I turned it on it started without any problems except one the Wireless connection never came online. I did several restarts I flipped the wireless switch several times still nothing. if I plug it directly into the DSL Modem the internet works fine but the Wireless capabilities are non existant.I also replaced the wireless card the wireless lite still stays amber and will not work plz help !
  • HP Master
  • 32,281 Answers
Check the Device Manager to see if the Wireless LAN device is working and enabled. If not reinstall the Wireless LAN driver.
If the Wireless LAN is OK and enabled then sometimes when you bootup the Wireless LAN card doesn't get an IP address from the wireless router. This usually has a red X on the wireless connection icon and sometime you get an error message "Limited or no connection".
To get the router to issue the wireless LAN card with a new IP address, righr click on the Wireless icon and click on Repair.
You can also power down the router wait 15secs and power up the router again then reboot the computer.
If it still doesn't work you could have a faulty wireless card, see it your friendly computer shop can test it for you.
Posted on Jun 30, 2009
  • 57 Answers
Hi! is your modem a wireless modem? if not, you won't be able to use your wireless adapter. You must have a wireless router or wireless modem so you could use the wireless adapter on your computer.
My laptop stopped picking up wifi after a much needed modification. I have a 3 year old hp pavilion dv9000. the hinges broke so I decided to remove the monitor of the laptop and hook it up to a desktop...
That is because the WI-FI antenna wires were on the LCD panel behind the glass.
Currently your laptop base has no signal. The only solution is that you may pick up a signal with the base alone, if it is near the wireless router about 20' (3 meters).
Apr 19, 2011 | HP Computers & Internet
Hello. I am Ali. I am from Iran. I have a HP pavilion dv9000 laptop.It had work very well till 2 weeks ago But my wifi doesn't work any more.I changed my OS and I re-installed my drivers and after that I...
I would first try to get into HP wireless assitant which you can do through Control Panel (Start >> Control Panel or Start >> Settings >> Control Panel). In there you can turn your wireless on and off. Be sure to make sure the wireless switch at the front is turned on also. If the light near the wireless switch still remains orange, then you will need to get the motherboard repaired or replaced as this is a known issue. If you still have warranty, HP will repair this free of charge. Otherwise contact a repair company such as www.revivemylaptop.com
Jun 09, 2010 | HP Pavilion dv9000t 17" Notebook Laptop PC...
My pavillion dv9000 laptop will not boot When I try to turn it on, the power turns on but it turns off by itself and turns on again and repeats it over again. I found out that other people are also having...
dv2000/dv6000/dv9000 recall
I have an out of warranty dv9000 and haven't had wireless for months. I just discovered HP issued a recall for the wireless and other problems with several different Pavilion and Presario models. For the wireless problem with the dv9000 they are replacing the motherboard on all notebooks in or out of warranty. I was wondering if anyone has had the repair done under the recall and how it turned out? I'm also wondering if HP is still cosmetically trashing notebooks when they are sent in for repair?
Here is the link for the recall:
http://h10025.www1.hp.com/ewfrf/wc/d...842189&lang=en
Mar 03, 2010 | HP Pavilion dv9000z Notebook
Can this HP Pavilion DV9000 adapter fit Presario V3000 laptop
just see it from http://www.udtek.com/hp-pavilion-dv9000-ac-adapter-90w-185v-49a-p-2970.html.may this is good for you.
Jan 15, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
Hp dv9000 switches on to show coloured lines on screen.
Hello
My first guess is that the screen circuitry has gone bad - although fixable. Use an external monitor to verify this. If the external monitor is fine then the screen circuitry is bad, if the external screen shows the same problem then the video chip or associated circuitry has gone bad. My company fixes these all the time.
Jul 28, 2009 | HP L1702 17" LCD Monitor
HP DV9000 Wireless Card Not Working
Did the wireless icon from your machine light up? If no, you need to re-install your wi-fi driver. If you have the cds with you, re-install the driver then switched on your wi-fi. If you dnt have the cds, try checking on the HP site and look for the wi-fi driver.
Jun 02, 2009 | HP Pavilion dv9000z Notebook
You may need to reinstall the drivers for the wireless card or repair the connection in the control panel under network connections.
Jun 01, 2009 | HP Pavilion dv9000z Notebook
Display Failure for HP dv9000 Laptop 17"
pls first check thru connecting normal pc Monitor as output from notebook see if monitor displays image if it doesnt then , do following
u should try replacing RAM if the system is not booting at all just fan is running and some light are blinking , then RAM is most likely giving problem try re fitting RAM , if u dont know how to let me know i will give u a tutorial for that . try taking out the RAM chips and then re fitting them individually i mean if u have 2 chips of suppose 512 mb each try one of them at a time
first take out both RAM chips and then re fit both and see if it works, if it doesnt then
try each one of them at a time se if u find the faulty one if it doent help then try a thrid one borrow it from someone and try but ur laptop needs to be same generation one u can ask me about the RAM model support and then try if it helps
other wise let me know
i will see more deep in the problem but i think it will resolve ur problem
pls rate me fixya if i fixed ur job
regards
zohail
Feb 28, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion Entertainment PC dv9000
Making a fairly confident presumption that your laptop is an AMD-based unit, model is....DV9205, DV9310, or DV9410
HP issued a service alert 07122001 covering such AMD-based laptops with your wifi failure, as well as additional failures within your product line. This is a warranty enhancement that will cover the replacement part and labor for you the customer.
HP has very recently started phasing out their older models like the 9005/9010, as the issue alert is basically good from 2yrs of date of purchase.
2 solutions for you....
1) Call HP and give them the serial/model info and inquire about that service alert # mentioned above, see if your laptop is still covered.
2) Replace the motherboard yourself and at your cost
(ok maybe another option)
3) Get a USB wifi card :/
-Sy
Aug 20, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
Contact HP for Care at ((+ 1-800-585-2494 ))
Toll Free Number
Apr 22, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000z Notebook Logo
812 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
