Question about Garden
I have a ryobi lawn mower with a 6.5 hp motor. it
I have a ryobi lawn mower with a 6.5 hp motor. it wont start. it backfires. i replaced the air filter, pulled the head off and cleaned both intake and exhaust valve. i also cleaned the spark plug. still not fixed. any ideas?
  • bradnbrittne Jul 02, 2009
    i cleaned them up real good. i thought that might be it but alas it was not!
I am working on one now. Customer said "it doesn't run". Ok. So, after oil/spark plug/air filter replacement...it didn't have any gas getting to the carb. Took off the bowl, and on this 2005 lawnmower, the inside of ALL of the carb was covered with a white/chalky film. Looked like tiny rust barnacles over ANY metal surface available. Silty white stuff in bowl. Blasted it all w/carb cleaner. Still couldn't get primer to work, but after I sprayed a bit o' starter in the cylinder, it started well & kept running. Until I let the bar down. Needs a new carb. Will see what the customer wants.
Posted on Jun 04, 2010
  • 365 Answers
Did you reface the valves and the valve seats?
Posted on Jul 01, 2009
Lawn motor backfire when starts?
Change the laminator. Part the spark plug wire is connected to. Air gap should be .025.
Jun 05, 2014 | Honda Gxv160 55hp 55 Hp 1" To 78" Lawn...
Lawn mower won't run. Cannot start it.
sometimes the primer bulb gets cracked and wont properly pump fuel into the carb. replacement of the bulb should fix the problem.
Jun 15, 2013 | Garden
Lawnboy 6.5 b and s motor was backfiring loudly when trying to start now when engine runs and heats up it cuts out and will not restart any ideas??? ran fine for a year and a half.
you need a valve job and have a unseated intake valve might have to get new motor if cant seat valve have to take to shop if cost 3rd by new mower
May 15, 2011 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
Tractor wont start
For a small gas engine than won't start, think FAST -- Fuel, Air, Spark, Timing. You've replaced the filters and spark plugs and squirted in some starter fluid, eliminating the simple common fuel, air, and spark problems -- but I because of the backfiring I think your problem is in the timing -- like a sticking valve. Probably more than you want to tackle at home, but might not be as expensive as an engine replacement. Take it to a good small engine mechanic -- best bet is a lawn equipment shop that has been around many years. Drive a little farther to get to one if necessary.
Jul 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Backfires through the air cleaner
This usually means a bent or sheared key in the flywheel. Remove the shroud exposing the flywheel buy a 6" flywheel puller and remove the nut for the flywheel and attach the three jaw puller remove the flywheel and replace the flywheel key. The only other thing that causes this popping through the carb is a burnt intake valve this is a job for a lawn mower shop.
Sep 30, 2009 | Garden
Lawn mower not running
sounds more like the carb sucked up something if u take it off and tear it down let soak in solvent than blow air thru body to dry and clear passages dont mess with adj
Sep 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engins starts and runs when mowing will backfire and stall.
I am not sure what time of lawn mower this is, but if the blade is directly tied to the motor, usually the belt will just slip if not, but if this is directly connected to motor, it might have jumped timing. If this is not the case, inspect under the mower deck, and determine if there is something jamming the blades against the deck or if their is something bound around the blade, this can cause more strain on the motor, which could result in the symptoms your experiencing.
Aug 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I started my craftsman 21hp 42in deck today it had a rough idle with backfire and when engade mower it seemed to not have enough power
Backfiring is a sign of too rich on gas and not enough air. Not enough gas will cause the mower to bog down when blades are engaged as it isn't powerful enough to run the motor AND turn the blades. Check your carb and see if you need to clean it and replace diaphgram. Sounds a lot like a carb problem.
Jun 21, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
1,413 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
