Forgot hp password ?Unlock hp name? You can also remove windows password? There are two methods to remove the password when you forgot the password. Method 1: Remove windows password with Windows built-in Administrator account Firstly, you start your locked computer as usual and press"Ctrl+Alt+Delete"twice when the Login Screen shows.Secondly, you just typeAdministratorin the username box and leave the password box blank. Thirdly, you hitEnterkey and then log into Windows system. Finally, you go to"Start->Control Panel->User Accounts"to find the inaccessible user account and then remove its password there. If the above method can not help you, you can use some windows password recovery software to help you, such as Windows Password Recovery Tool, i ever used to help me , it can help you finishwindows password remover
Here I collect some popular solutions to help reset HP laptop password if your laptop installed Windows system such as Windows 7/Vista/XP.
Solution 1 Reset HP laptop password by another user account with administrator privilege.
Solution 2 Reset HP laptop password with Offline Windows Password & Registry Editor.
Solution 3 Reset HP password with professional password recovery tool.
If you do not have another administrator account on HP laptop or you have little experience in Windows or LUNIX operations, you can use Windows Password Rescuer to help reset HP password without lose date. This software was provided by DAOSSOFT corperation, it supports HP laptop password recovery in Windows 7/Vista/XP and HP computer installed Windows 7/Vista/XP/2008/2003/2000.
If you have windows XP, boot the computer in safe mode. When you start the computer keep tapping the F8 key to the advanced boot menu. Select safe mode. It would give you the login screen. Select Administrator, do not enter any password, if you can get through, it means that you did not setup a password for the system administrator. Once you get to the safe mode window with the icons, you go to start, control panel, user accounts, select the user account that you used to login and delete the password. You can retype a password again and exit out of the window and restart the computer. You would be good to go.
If you have windows vista, and you have created the password reset disc, you can use that to reset the password. You need to boot the computer with that disc. if not, you need to run the system recovery on your computer.
reboot the computer and hit F8 key continually to access the boot menu
Choose Safe mode
Log in the "Administrator " Account. Password should be blank.
Once logged in, go to control panel....Users account....change an account
Choose yours and change the password.
reboot
