Question about Maytag 30 in. Admiral LGC1330 Gas Cooktop
Stove top is hot
I came home from work and found that the top of my gas stove is really hot even though it was off for about 10 hours. Should I get out of the house?
    Novelist:
  • 222 Answers
I think have an leakage in ur unit,much better to call the tecnician coz its very dangerous for u if u not check asap.
Posted on Jul 04, 2009
  • gerbee gomez Jul 04, 2009
    i think have an leakage in ur unit,much better to call the tecnician coz its very dangerous for u if u not check asap.
What may cause the oven overheating during self clean
well last time I checked the self clean went to around 600 degrees . has to to burn off the stuff burnt on inside . and YES outside gets really hot .
Aug 28, 2014 | General Electric Ge Stove / Oven / Range...
Gas stove tops: After 3-4 minutes of the gas being on for one or more burners, all of the ignitors keep on attempting to spark. They keep going even after the gas has been turned off and stop after 5 or...
Hi abbilou_78,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 30, 2011 | Whirlpool Cooktops
Burner shuts itself off after 10 0r s minutes of working normally
this unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
Jul 12, 2010 | Thermador PC366BS Stainless Steel Gas...
My stove top now keeps clicking, even when it is
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Mar 26, 2010 | Jenn-Air JGD8130 Gas Cooktop
Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
Feb 04, 2010 | Miele 36 in. KM3474 Gas Cooktop
Streaky, filmy black stove top
Re: Streaks
After a final clean up with a a wet & well rinsed cloth buff the surface with a microfibre cloth & it will look like new.
If there re any difficult ares to remove use a glass cooktop
paste cleaner (from Sears, etc)then and finish off with the microfibre cloth.
May 25, 2009 | Cooktops
GE Profile igniter sparking continuously after water spill
The continuous sparking stopped after few hours. Looks like the water dry up and that fixed the issue.
Mar 19, 2009 | Jenn-Air JGC8536 Gas Cooktop
Ignition sparking on its own with GE mongram gas stove top.
the sparking is one of the switches under the knobs shorted you may be able to open the top and take a switch off 1 at a time and you can figure out what one is shorted.or you can just change all of them.
to stop this you may be able to just unplug the cooktop from under the top.if you unplug the cooktop you should be able to light the burners with a match.
Nov 14, 2008 | Cooktops
Cleaning grates of GE profile gas stove
Sounds crazy, but this works. Soak the grates in warm to hot water with 2 dryer sheets (Bounce), let them soak for an hour or two. Unbeliveable how they came clean. I did have to use a Scotch Brite pad on the two that I use most, but it sure beats replacing them.
Jul 02, 2008 | GE Profile JGP636 Gas Cooktop
Maytag 30 in. Admiral LGC1330 Gas Cooktop Logo
406 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Marvin
Marvin
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
