Unit keep on going out on lock out - Heating & Cooling
    Scholar:
  • 70 Answers
Wash out outside coil with hose with 30 degree downward starting at the top and work side to side to bottom and try again. If this don't help check evap coil (inside) for ice forming when unit is on. You should see a 15 - 25 degree drop from room temp coming out of discharge air. This will change with humidity indoors. as it drops temp will too.If outside coil is dirty or unit is low on gar it will cause high compressor and high disgharge lockout. Low gas can also cause freezing of indoor coil and loe temp or pressure lock out depending on type of protection incorporated.
Posted on Jun 30, 2009
Bose Solo TV unit keeps locking out (no sound) Can
You can go to the repair shop for fix it. Since this unit can be defective by IC, ROM or RAM. or audio circuit+power supply or defective solder.
God bless you
Nov 01, 2013 | Bose Solo TV sound system - Black
I cant get my kenmore elite he3 washer to start keep getting dl F error
Possible causes: (power off the mains first before checking)
Door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
1. Check door switch/lock unit.
2. Check the wire harness connections of the door switch/lock unit to the Central Control Unit (CCU). The wires shd be secured well.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
May 04, 2010 | Kenmore Elite 45986 Front Load Washer
Doorlocks keep locking even when out of the
Dave, it would appear that at one point one of the manual locks were forced either to unlock or lock and has now repositioned the nuetral point at a different location on the locking rod, hence, sending false readings to the control unit to either unlock or lock, I would try this, close all doors and manually lock them see which lock lever look unlike the rest in that position, this will be the culprit and have to be reset on the rod behind the door trim panel. This advice is as best as I can give without manually seeing the car. Drive safely
Jan 19, 2010 | 1999 Pontiac Montana
Unit keeps locking up and i have to power cycle the unit to get it working again my last trip was 3 hours long and it locked up 4 times
When a Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
  1. Perform a Hard Reset,
  2. Run WebUpdater to reinstall the firmware.
I hope that helps.
Nov 14, 2009 | Garmin nuvi 205 GPS Receiver
Door lock failure
It sounds like your door lock unit has a bad wax motor. There are 2 wax motors on the unit. 1 which actually locks the door and 1 that presses down on a check switch to tell the computer board that the door is locked. The wax motor that is bad is the one that presses down on the check switch. It is not a part that can be replaced on its own and you will need to change the entire door lock unit
Jan 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
TOMTOM 510 locks up
try to upload new maps on the unit
Mar 22, 2008 | GPS
Magellan Maestro 3100 locks
You can try a hard reset. Hold in the reset button (left side of unit, use a pin or toothpick), while turning on the unit. If you don't get the blue Magellan screen, you'll have to try again. If you get a screen with a blue background and a menu, turn it off and try again.
So far, this has fixed:
1. unit won't go on
2. unit reboots when routing
3. unit turns off after a few seconds
At least, it's fixed it for me. No idea why this happens, but it's pretty damn annoying. Give it a try.
Dec 26, 2007 | Magellan MAESTRO 3100 98083401 GPS Device
Frigidaire range
Unplug the unit, then manually depress and hold the light switch on the frame of the unit while plugging it back in. The lock should go back into the proper position.
Craig Mac
Nov 16, 2007 | Frigidaire FEF376 Electric Kitchen Range
Sony SNT-V704
If your unit keeps crashing this could be a sign of over heating. There is a way to test if it is an overheating issue and that is as the unit is playing use a hot air gun to raise the temperature and trigger the problem once the bad component is found replace it.
Sep 12, 2007 | Sony SNT-V704 (SNTV704) Video Server
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
