It's likely that mineral build up is causing this. Put some white vinegar in the reservoir with your water.Allow it to sit a bit, working the trigger. Then put your mop in the bath tub or somewhere that you can allow it to steam without concern. Steam the entire contents of vinegar/water through. The vinegar should clear out the mineral deposits.
Did you use third party carts?
If yes, buy original brother ink carts and do the cleaning cycle again. If you are lucky the printhead isnt clogged due to the third party ink which has not the additives and glycerin needed for the printhead to run without probs.
In case the head is clogged there is nothing more what you can do. Sorry! A replacement might costs more than a new mfc 440cn!
