Question about GE Profile JGP636 Gas Cooktop
Need replacement drip pans for ge xl44 gas stove
Where can I find replacements for double drip pans for black ge xl44 gas stove
  • Anonymous Mar 15, 2014
    how do i place my drip pans on my wolf 6 burner stove
    Novelist:
  • 222 Answers
U can find the parts only in the service center of GE appliance center.but if ur unit is more than 10 years,im sure no parts available.
Posted on Jul 04, 2009
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
Light "Burner On" stays on all the time on my electric stove GE model JBS27WH2WW
I have a GE Range Model JBS27W H2WW and the serial# XXXXX that I was cooking on and the back burner starting throwing out sparks and blew a hole in the coil and the drip pan. Now the light Burner on is staying on and I switched the 8 inch burner in the front with this 8 inch burner and still cannot get it to work.
Dec 19, 2013 | Cooktops
How to replace a cooktop drip pan
It's really simple. Remove the burner grates, removed the old drip pans, then drop in the new drip pans. You can order a new drip pan from partselect.com if you don't have one yet. Let me know how this works out and if you need any further help.
Benjamin
Nov 04, 2010 | GE Profile JGP636 Gas Cooktop
How do I clean stainless steel stove?
Send me an email and I can direct you to what we use and sell, help@timerking.com.
Hope this helps!
Nov 04, 2009 | Cooktops
Non stop clicking on GE XL44 stove
water got into your switches..or one has gone bad. if water, let it sit a few days and dry out. turn off power.
if not, switch, under knob one of the 4 or 5 if you have 5...is faulty..needs replaced
Oct 24, 2009 | GE Profile JGP636 Gas Cooktop
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Oct 15, 2009 | GE Profile JGP636 Gas Cooktop
Does not ignite
Check to make sure that the gas is getting to the igniter. If you can ignite with a lighter or match, than the igniter itself needs to be replaced.
Apr 01, 2009 | GE 30 in. JGP326 Gas Cooktop
Ventilation system on Jenn Air CVG4280
My Jenn-Air had the same problem. When you install the drip pan for the burner module, there is a "finger" on the pan that is inserted into a hole in the front of the stove. If you look into that hole, you will see a lever switch. The finger on the drip pan on the burner module is supposed to push that lever switch down and turn the fan off, but over time the lever gets pushed down further and ultimately it does not get activated when the drip pan is installed.
You can either replace the lever switch, or you can try to pull it back into place and tighten the two small screws that hold it in place. Actually, I chose a third option and attached a small, flat spring to the finger on the drip pan.
Oct 17, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
GE Profile JGP636 Gas Cooktop Logo
2,053 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
