Question about Vizio SV470XVT 47 in. LCD TV
No video. LCD comes on. Sound works. Suspect PC Board or LCD Interface, need suggestions.
  • leafweir Jun 30, 2009
    Don't get menus. It started flickering, then faded to grey. Now it just comes on with sound but no video (Black, but backlit).
  • leafweir Jul 01, 2009
    I've ordered the PC board, if that fails, I'll get the direct interface and try that
    Sergeant:
  • 246 Answers
The LCD control board is defective. Normally the LCD control board comes with the LCD panel (with a shield coved on the back of the panel). Check you user’s manual, call the service center to see what they can do.
Posted on Jul 01, 2009
Screen is blurry, it was dropped
You may have slightly dislodged the video interface ribbon cable that goes between the laptop's main board and the display itself. Or you may have damaged the LCD itself. Working on laptops can be tricky business and sometimes special tools are needed. If you feel brave you can remove the key board to inspect the connection between the laptops system board and the display. Before doing this I highly recommend you search for videos on disassembling your laptop on YouTube. Hope this helps.
Aug 29, 2016 | HP Pavilion Chromebook 14
The lights are on, but picture won't come on.
A suggestion: if you have sound look at the screen with set on in a dark room with a flashlight---do you see a very faint image or not?
If no sound or brightness but indicator lights are on suspect another issue--possible power supply board is bad.
Nov 07, 2012 | Emerson 22" Class LCD 720p 60Hz HDTV,...
I have a Sony KDL-46S4100 LCD that was given to me that doesn't work. It powers on and the power LED is green and the backlight to the tv works and stays on as well but I get no picture or on screen...
T'Con board fault. Check and replace it. For most model Sony TVs, T'Con board is an integral part inside the display panel assembly. If your TV model have such a display panel; there is no way to replace it. The only thing you can do is to replace the display panel. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 08, 2017 | Sony KDL-46S4100 46 in. LCD TV
HI WHEN WE TURN OUR LG 42 INCH LCD TV ON IT WORKS OK FOR ABOUT 30 MINUTES THEN THE PICTURE GOES AS THE SCREEN GOES WHITE THE SOUND WORKS FINE AFTER ABOUT A HOUT THE PICTURE COME BACK AND IN OK ...
I suspect you have a poor contact on the video processor board or the upscaler itself on the screen.
Check all ribbon connectors and look for any components that have got very hot, there may be a dry solder joint beneath them.
Hope this helps.
Nov 27, 2010 | LG 42LG70 42 in. LCD HDTV
My tv comes on but has no picture or sound...screen is black
do you see the menu if you hit the button? If not look thru vents in back of set to see if see lights coming on. Most lcd displays have holes in them so you can see if the backlights are coming on. this lights the panel so you can see the pix. If it doesn't light unfortunately there are several things in lcd that can cause that.If you don't hear sound I would suspect the main pcb or mother board of set. It is usually the board that has all the audio/ video connections on it.
Sep 11, 2010 | Philips 32PFL5332D 32 in. LCD Television
Ok i have an hd pc monitor and when i turn on i get a whit screen
dani. If you can verify your PC is working ok and capable of driving a known good monitor, you will at least narrowed down problem to your white screen lcd! Always state the make and model in the text body of your post to fixya. I usually only do BLACK screen fails, but here goes anyway. The vga input to LCD digital output interface board is telling the lcd panel to turn all pixels "ON" !! If monitor worked ok the day before--then it should work fine today? NO! something has changed! When strange things start to occur on lcd panel I would first suspect the "switch-mode-power-supply" as the trouble maker. If you haven't a clue as to how a SMPS does what it does, then you will need to find technician or TV repair shop that also knows forward and backwards all about lcd monitors. I do suggest that you visit youtube for videos on lcd monitor disassembly and LCD monitor repair so you can see what is inside a typical unit. FYI visit www.ccl-la.com/badcaps.htm and www.badcaps.net Well, anyway, your CCFL backlights STILL work!!
Although most of my responses are to Black/Blank screen you may find other options that will suit you a little better. 12fixlouie
Dec 15, 2009 | E-Machines eMachines Monitor E15T4
I have an Olevia Syntax LT27HV LCD TV that lost sound. Do you know what board fixes this problem? The manual says maybe interface board or system board.
It depends on where you lose the sound, no sound from speakers? no audio line out?
The amplifier circuits are on the main board. You should try hooking up a powered PC speakers to the audio line out to see if you get the sound, if you do, then the power amplifiers are bad (it is a single IC Class D dual amplifiers, IC U54 on the main board)
Sep 22, 2009 | Syntax LT30HV 30 in. HD-Ready LCD...
Dell 17" LCD TV takes a long time to come on 15 minutes or more
popping noise is an indicatior of a bd board. if the unit power light still lights amber, it probably the main board else the power board a circuit or two may have been fried. both boards need to be examined. questions, email me
Feb 05, 2009 | Dell W1700 17 in. HD-Ready LCD Television
BenQ FP71E doesn´t gives video
This suggests there is a dry joint on on the printed circuit board. I would go over with a soldering iron on all joints that look suspect.
Jun 02, 2008 | BenQ FP71G 17" LCD Monitor
Visual
I would heat it up with a hairdryer and then get it extremely cold and see if the picture comes back while watching it. If it does, you most likely have a fractured solder connection somewhere in the set and it needs repaired. IF nothing changes then i suspect a board might have failed or worse yet, the LCD Panel or the video processing board. Also you might want to try all the inputs to see if any other one works. Does it have a VGA input? try and hook a computer up to it. Good luck Guru Jay
Oct 15, 2007 | Maxent MX-27X1 27 in. HD-Ready LCD...
Vizio SV470XVT 47 in. LCD TV Logo
160 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
