Question about Canon PIXMA iP2000 InkJet Printer
I have the exact same problem
My Canon Pixma ip2000 is going through the motions but no print is showing up on the page. I have replaced the cartridges and done several cleanings and nothing helps.
  • Canon Master
  • 365 Answers
Try and soak the head in warm water mixed 15-20% ammonia for 30 minutes.Dry completely and stick head and carts back in,Do a nozzle check
Posted on Jun 30, 2009
Canon Pixma ip2000 Inkjet printer wont print black. Replacing cartridge did not fix the problem.
Remove ink cartridges,then print head.
Clean print head with dry cue tips.
Apply strong suction over black print
jets on print head.
Replace print head and cartridges.
It worked for me.
Oct 17, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon Pixma iP2000 wont print black ink?
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Jun 02, 2009 | Canon PIXMA iP2000 InkJet Printer
My printer, the Canon, Pixma Ip2000 stopped printing. It was giving me the message "the waste ink absorber is full". I took it to the only canon dealer in the city, and he reccommended that I replace the...
Reset Printer Canon IP2000 / IP3000
By pelda
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
http://freeresetterprinter.wordpress.com/2008/09/05/reset-printer-canon-ip2000-ip3000/
Mar 26, 2009 | Canon PIXMA iP2000 InkJet Printer
Won't print at all
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA ip2000 assembely
Shaun,
Please click the below mentioned link to visit Canon PIXMA iP2000's manual page:
Canon PIXMA iP2000 Manuals
Thank you
Aug 25, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon Pixma iP2000
try cleaning the print head as follows, otherwise a new print head.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jun 28, 2008 | Canon PIXMA iP2000 InkJet Printer
Printing a document on a pixma ip200
you may need to change the paper source in the printer setup for whatever is printing
Mar 18, 2008 | Canon PIXMA iP2000 InkJet Printer
IP2000 print head won't center
try to unplug the printre while the print assembly is on the middle
Jan 14, 2008 | Canon PIXMA iP2000 InkJet Printer
Pixma ip2000
waste ink absorber is full what can i do
Nov 29, 2007 | Canon PIXMA iP2000 InkJet Printer
Printer is going through the motions but is printing blank sheets
no tengo el instalador de la impresora canon pixma ip 2000
Aug 06, 2006 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA iP2000 InkJet Printer Logo
122 people viewed this question
old marine
old marine
