Question about Bassett Mission Crib
The crib makes use of springs. I'm not sure where they go. Also, the proper placement of the bed rails.
    Brigadier General:
  • 8,619 Answers
Hi
Please check the link for the manual which will explain you about the proper placement of the bed rails. Also if it does not help then you can call Bassett at 1-877-525-7070 & they'll be happy to assist you.
Bassett Mission Crib Instructions Manual
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 30, 2009
Need instruction to put crib together
1.Find and read the instructions carefully before doing anything. Become familiar with the instructions so that even if you do not remember everything, you have a basic idea of how to proceed before you start. Look on the manufacturer's website for directions if you have lost the original instructions.
Assemble the parts. Make sure you have all of the parts and all of the screws that are listed in the instructions, and that they are in working order. Lay out the parts so that everything is where you need it and you can clearly see all of the parts.
Set up the head and foot boards and attach any stabilizing bars. Some springs attach directly to the bed and some are movable, so you will either attach the spring board or you will attach the pieces that the spring board sits in if they are not part of the crib already. If the spring board is movable, put it on the setting that is the correct height for your infant (higher for newborns, lower for older babies).
Attach the back of the crib that is stationary and does not move up or down. The front part of the crib often is adjustable and lowers and raises back to a stable position. You may have to install rails for this part of the crib, then install the front portion onto the bars and then screw the bottom of the rails into the crib.
5
Put the mattress in the crib and make sure it fits. Test the crib by feeling to make sure that it is steady and not going to come loose. Make sure all of the screws and bolts are tight and that none are sticking out in any way. Make sure there is nothing that could hurt the infant such as any sharp edges or splinters
Jul 27, 2011 | Toys
I have a vickie crib .I want to convert to toddler bed. If I take the front rail off there is'nt anything to hold the bed up in the front. It unscewss from the side. Help! Bed was purchaced 9/2008 ...
Is this a 4-in1 convertible crib? The Toddler bed will need the bottom railing and a half rail to convert from a crib to a toddler bed. The half rail can also be removed to make the 4th conversion to a toddler bed with out railing. But to convert this specific bed you DO have to add the bottom rail that came with the bed at purchase.
Mar 10, 2011 | Sorelle Vicki
Delta soho 5 in 1 crib where can I get the conversion kit for the toddler bed and where can I get the rails for the full size bed
You can find Delta soho 5 in 1 crib conversion kit on amazon. Click here Amazon com Delta rails and take a look. I hope this was helpful. cheers
Jun 29, 2010 | Delta Soho Crib
Converting Delta Martinique 5-in1 Crib to single bed
I have the same crib and it can be transformed into a toddler bed by removing the front rail and it can be transformed into a full size bed using a full size bed frame and the front and back rails of the crib.
May 30, 2009 | Delta Martinique 5-in-1 Crib
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
Need instructions on how to convert my aspen simplicity crib into a toddler bed?
i think this is the same crib that i have. I remove the front rail that slides up and down, then i removed the plastic contraptions that allow it to slid up and down on. I then attached the bed frame on the lowest setting, by first fastening the two back ends first. Then I attached the toddler rails to the bottom of the bed frame and then once they where on I attached the bed frame to the crib with the rails and the brackets for the bed frame pressed together. I hope i explained it so that i makes sense.
Mar 14, 2009 | Simplicity for Children Aspen 3 in 1...
Jardine convertible crib instructions
Hi, I know it looks hard but It's really simple .just take out the screws that are on each side on the bottom and top 1 on the top and one on the bottom each side( 4 in total )(Sides not on the front) and that's it, the front part comes off and you save it for when you make the bed a full size bed wich that part becomes the foot board. Hope this information helps! Good luck!!
Jun 11, 2008 | Baby Gear
Convert to toddler bed
They do have answers on their website, you may want to check your printed or online crib instructions to remind yourself how you put the crib together, too.
I found the answers here:
http://www.pali-design.com/index.php?path=customer_services&template=faq&section=customer_services&subsection=faq&page=faq
i've pasted them below. You can make it a toddler bed without a side rail just by removing the movable side of your crib, and you can install the side rail instead of the movable side if you want it to look a little more finished and help keep your child from rolling out of the bed.
FAQ
How to convert a crib into a toddler bed
To convert a crib into a toddler bed you must loosen the two front gold bolts left and right side of the crib and remove the dropside (the front gate that goes up and down). After removing the dropside be very careful that you tighten back your two gold bolts.
How to install the streight rail (toddler rail)
To install a streight (toddler) rail loosen the two front gold bolts left and right side of the crib and remove the dropside, once you have removed the dropside replace with the streight rail. Always be very careful and make sure you tighten back your two gold bolts in the front.
Oct 14, 2007 | Pali Sabrina Crib
Converting crib into toddler bed
Typically you can loosen the bolts on the side of a crib slowly until you get to a point where the front rail will pop out of its track. After it is removed tighten up the bolts again! I am not sure what crib you have or if that will work the same way with your configuration. You should make sure you have the springs at the lowest position as well. You will then have a 3 sided toddler day bed. I hope this helps. Richard - www.goores.com & www.gooresblog.blogspot.com
Jul 14, 2007 | Kinderkraft Vermont Crib
Bassett Mission Crib Logo
117 people viewed this question
Top Bassett Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Tom Chichester
Are you a Bassett Baby Gear Expert? Answer questions, earn points and help others
