Question about Little Giant Pump P-AAA 120GPH Sub Pump
Our little giant P-AAA is leaking oil, can it be repaired with a new seal or is it past it's life
2 Suggested Answers
  • 1033 Answers
SOURCE: my Little Giant VCC-20ULS is
Hello, Most likely the pump just need to be cleaned out. Turn power off and clean out pump with soap and water.
Posted on Aug 16, 2011
How to disassemble Little giant pump model#psm006?
thats why i like the little giant pumps they are put together with phillips screws not glued like them other guys , i do suggest that if you dissasemble pump and water has gotten inside , replace it not just seal it up and go , wont last long as that means the pump shaft seal has leaked , ther e has been a few folks that add dietary mineral oil to the inside , for use in very deep ponds (over 3 feet) they believe that helps keep the water out
Jun 11, 2014 | Little Giant Submersible Fountain Pump
2 Things on my 2005 SRX. I keep getting check gas cap messages and replaced the cap once but am getting the messages again. Also, the system says my Engine oil life is still at 69% or so and the check...
Could be leaking from valve cover , or valves are not seated right. Though the piston rings . Or the seals on the valves are bad ( think there called o rings)
Dec 13, 2017 | 2005 Cadillac SRX
Smoke from exhaust when start ls400 model1991 lexus color of smoke is gray it ends few second
the smoke is from engine oil, it is caused by leaking valve seals , after the engine is shut down for the day oil is leaking past the valve seals and getting into the cylinders then when you start up the engine the oil is burned off, this is a common problem, and there is a couple of things you can do to help the problem with out taking the engine apart and replacing the seals, try this first at your next oil change add some Restore to the engine oil it will soften the seals and give them a little more life, if this does not cure the problem after a few 100 miles then you will need to have the seals replaced, and this is a costly repair, but you could just live with the smoke it wont hurt any thing just keep an eye on the oil.
May 17, 2011 | Lexus LS 400 Cars & Trucks
My lexus ls 400 model 1991 when start gray smoke ocurr for few second then disappear
May 17, 2011 | 1991 Lexus LS 400
When i do oil change, oil leaks somewhere around the oil filter, after the engine warm up leak stops. is not leaking its driping.
when you remove the old oil filter. insure the old filter seal came off with the filter. then when installing the new filter wet the new seal of the filter with a little oil. just dip your finger into new oil and smear it on the seal.
Nov 29, 2009 | 1993 Lincoln Town Car
What oil can I use to top up the motor on a Little Giant NK1
Submersible pumps usually use #10 non-detergent oil.
Oct 12, 2009 | Plumbing
Little Giant Pump - dialectic oil to use
ck your local yellow pages for an electric motor repair shop they should be able to get silicone oil to add , but in a pinch ive used full synthhic auto transmission oil that works too
Jul 29, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Little giant submersible water pump (model 5-mspr) is low on oil...what type of oil should I use to top up the oil level???
You can use a dielectric oil available at most motor repair shops. It is of the utmost importance to make sure the cord seal is in good condition and well sealed
Apr 22, 2009 | Pool & Spa
OIl leak in 2001 Grand Cherokee Laredo
valve cover gasket is like $20 and a do it yourself job, just buy a manual like a chiltons from an auto parts store. if it was valve cover, the smoke would be coming from engine, not tailpipe.
rear seal is in between engine and tranny, this would cause oil to leak on ground, but not to burn
if smoke is coming from tailpipe, your piston rings might be going bad. that is an expensive repair, but switching to synthetic oil may give you several more years of life out of the piston rings, synthetic oil has a way of soaking into bad piston rings and temporarily making them like new again, unless they are already too far gone.
Nov 24, 2008 | 2000 Jeep Grand Cherokee
Little Giant Pump P-AAA 120GPH Sub Pump Logo
151 people viewed this question
Top Little Giant Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Little Giant Pool and Spa Expert? Answer questions, earn points and help others
