Question about HP Officejet 5610 All-In-One InkJet Printer
How do i clear paper jam with out pulling paper from front
  • 102 Answers
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab54
Posted on Jul 17, 2009
  • 56 Answers
How to fix brother printer paper jam error
Follow the steps below to clear the paper jam.
  1. Pull the paper tray completely out of the printer.
  2. Pull the jammed paper up and out of the printer.
  3. Press the cover release button and then open the front cover.
  4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. To prevent damage to the printer caused by static electricity, DO NOT touch the electrodes shown below.
  5. Open the back output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7. After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
  6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  7. Close the jam clear cover. Close the back output tray.
  8. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
  9. Put the drum unit assembly back in the printer.
  10. Put the paper tray in the printer.
  11. Close the front cover.
http://support.brother.com/g/b/faqend.aspx?c=hk&lang=en&prod=hl5040_all&faqid=faq00000026_010
Sep 11, 2017 | Brother Office Equipment & Supplies
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Dec 21, 2010 | Office Equipment & Supplies
Paper jammed - how do I get it out?
  • Follow the below steps to clear the paper jam
    Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
  • To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
  • For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
  • Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
  • Try printing another document.
  • Nov 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    How to open drum to remove the jammed paper inside
    Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
    4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
    5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
    7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
    8. Pull the Duplex Tray completely out of the printer.
    9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
    10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
    11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
    12. Put the drum unit assembly back in the printer.
    13. Put the paper tray in the printer.
    14. Close the front cover.
    Oct 19, 2010 | Brother MFC-7440N Laser Printer
    How to clear paper jam in HL 5040 laser printer
    Clearing paper jam in a printer is simple almost seven step procedure.
    i. Put off the printer.
    ii. Open all the covers/shutters on the printer (usually one in front or top and one at the back.
    iii. Now pull out the cartridge carefully.
    iv. Site the paper that has jammed and pull it out in the opposite direction of its movement. (Pulling the paper in the opposite direction is important for the printer mechanism).
    v. Return the cartridge and press it firmly inside.
    vi. Close all covers.
    Power on your printer and you should be able to print again.
    Dec 04, 2009 | Brother HL 5040 Laser Printer
    My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
    Observe Cautions signs in printer.
    Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
    1. Press the cover release button and then open the front cover.
    2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
    3. Pull the paper tray completely out of the printer.
    5. Pull the jammed paper up and out of the printer.
    6. Open the front cover again.
    7. Open the back cover.
    8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
    9. Using both hands, gently pull the jammed paper out of the fuser unit.
    10. Close the back cover.
    11. Pull the duplex tray completely out of the printer.
    12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
    13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
    14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
    15. Put the drum unit and toner cartridge assembly back in the printer.
    16. Put the paper tray firmly back in the printer.
    17. Close the front cover.
    18. Make sure that the Paper LED is now off and the printer is ready.
    After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
    Dec 04, 2009 | Brother Office Equipment & Supplies
    Paper jam and still won't print
    Hi
    Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
    Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
    1. Pull the paper tray out of the machine.
    2. Pull out the jammed paper.
    3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
    If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
    4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
    5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
    6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
    Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
    8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
    Please do rate the solution and revert for further assistance.
    Thanks
    Rylee
    Aug 15, 2009 | Brother Office Equipment & Supplies
    PAPER JAMMED-PRINTER HL5150D
    Hello a_bowen1
    You can clear the jammed paper as follows.
    Note
      • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
      • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
    1. Pull the jammed paper up and out of the printer.
    1. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
    hl50_05712.gif Caution
      To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
    1. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
    Note
      If you have to pull the paper toward the back of the printer, the fuser may get dirty with toner powder and it may scatter on the next few printouts. Print a few copies of the test page until the scattering of toner stops.
    chap0615.gif Caution
    1. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
    1. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
    1. Pull the Duplex Tray completly out of the printer.
    1. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
    1. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
    hl50_047.gif Caution
      To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
      If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
    1. Put the drum unit assembly back in the printer.
    1. Put the paper tray in the printer.
    Good Luck and don't forget to leave a rating based on my solution:
    Mark
    Apr 04, 2009 | Brother HL 5150D Laser Printer
    HL 2040 paper jam light is blinking but there is no jam. the printer sounds like it dies out everytime it tries to print.
    Often the paper jam light will stay on when the *back* paper jam door is not cleared.
    Open up the back of your printer. There is a 2nd door behind this door that you can pull open. If there is a paper in this section, pull it out and it should clear your red light.
    When clearing paper jams, clear the front first, and then if the red light is still on, you need to check the back hidden door for another piece of paper.
    Dec 08, 2008 | Brother HL 1440 Laser Printer
    HP Officejet 5610 All-In-One InkJet Printer Logo
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
