I've got a goodman GSC140241AA ac unit (which is
I've got a goodman GSC140241AA ac unit (which is only 3 years old) and it stopped blowing cool air. The indoor and outdoor unit are working, as in turning on. I've noticed that the indoor unit is not sweating so I belive it has low freon, a technician confirmed and said it was leak from a bad evaporator coil. My question is should that part have gone bad that soon, and how would I replace it?
  • 1 more comment
  • mullins8016 Jun 30, 2009
    I've called the home builder and the gave me the # to the installers, which was the technician that came out. They said all parts are covered but the labor is $800. I asked for them to break it down, ie how many man hours is it and the price per hour but was told it was a solid price, it was for the labor and the fee to go get the part. Two different answeres from technician.
    Would calling Goodman directly help at all, would they cover the warranty?
  • mullins8016 Jul 01, 2009
    Scholar:
  • 70 Answers
No it should not. If their is a leak and it can be reached the coil should be repairable. Replacing it will require a pro to replace it and recharge system. Not a user friendly item. Also may need a line drier and a vacuum pulled on system. You need a license to handle R22 and this may be an R 410a system which requires special gauges. But I would try to go back to the installer and or Goodman about the leak.
Posted on Jun 30, 2009
I have a Goodman GPH1324H21A the fan comes on and the AC kicks on for a couple of minutes then shuts down what's wrong with it?
if it's 4 years old it doesn't have r22. Are BOTH fans running when ac shuts down? Inside unit or outside unit shuts down?
Jan 08, 2018 | Goodman GPH1324H21A WallWindow Air...
My AC unit model is CPLE60-1. It is running, blowing cool air but not cooling house. Any Suggestions? and what is the life expectancy of this unit?
Your Goodman unit is a five ton and should last 15 to 10 years with proper maintenance. Parts do wear out though during the normal life of piece of equipment.
Cooling problem may be due to low charge, broken ducting, or other low airflow problem. Need to verify freon charge and then go from there.
Jul 27, 2011 | Goodman CKL36AR36 Air Conditioner
I have a goodman CKJ42-1B air cond. unit. It keep tripping my AC breaker although continues to blow air - just not cool air. Once I turn OFF then ON the breaker the AC works fine for about a day. Then...
try cleani ng the unit outside with your garden hose first .sounds like its kinda dirty .the dirty er the coil is the higher the amp draw is when it is running .what size is the breaker in the box .thats a 3 an a half ton condensor
Aug 06, 2010 | Goodman CKL36AR36 Air Conditioner
AC not cooling
first off you should have a four ton unit. what is your super heat? is it pulling attic or outside air?
May 27, 2010 | Goodman CLQ36AR49 Air Conditioner
Goodman 3 ton outside unit fan not blowing
Motor, wiring and/or capacitor. If the sticker on the side of the motor isn't burned off you can get the motor info off that. Model numbers from the motor do little for locating the motor but my help. Best thing to do is get the AC motor specs and look up online (cheapest) or go to a motor shop. The specs you need would be as follows.
Horsepower-Such as 1/4 or 1/3
Voltage-Most likely 240/1 (240vac single phase)
Rotation-CW/CCW looking at the shaft end of the motor
Amps
Frame size
Jul 10, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman CKL60-1 Condenser Fan Runs OK, then stops
check connections tightness or if you just change the connector will solve the problem that is if the motor has not burn out yet
May 28, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman not working on auto on in the "on" position
The first job of an ac is to dehumidify.Is the heumidity high?If so,give it time.
Mar 09, 2009 | Carrier 38CKC036 Air Conditioner
Bad bearings on the motor or check the fan rotations . Air should always blow out the top and **** in through the sides or coils.!... Thank-you-very-much!
Aug 25, 2008 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
155 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
