Question about Sony PS3 40GB Best Sellers Bundle Console
PS3 only gives a blank blue screen.
Have tried all the fixes. Holding down the power button to reset the video settings. Nothing has worked. Help
Try thi video .....it is in Youtube and I think it will work for you! Please let me know if it worked.
http://www.youtube.com/watch?v=ntClBMNwXlw
Marium M
Posted on Jun 30, 2009
Emerson dvd/vcr remote not all buttons working but all pass the Infrared test.....help?
The buttons are not making good contact with the circuit board. There are repair kist that have a liquid that restores functionality. http://www.remotecontrolsinc.com/shop/remote-controls-inc/remote-repair-kit
Dec 17, 2016 | Office Equipment & Supplies
My nextbook 8 will not reset tried holding power button a few secs longer than powering off then restart the device will not start help
Try a reset. Grab a paperclip, look for a tiny hole - probably on the back, straighten the paperclip and gently press it into the hole. It woks for me on my Hudl!!!
Feb 11, 2015 | Nextbook Premium 8 Se Android
I tried to change my password and i closed the page before it finished and when i tried to connect to the internet it wont work help
Perform a reset. Find the hidden reset button, usually close to power line, find a small hole with a little button behind it. Use a toopick or similar to hold down power button for at least 10 seconds. This should restore it to factory setting and default password. Google the model # and brand and "default password" if you don't already know it. If this does not work to reset it, then try this...
Hold down reset button for 30 seconds, still holding button pull the power out, keep holding button for 30 secs, STILL holding button - plug in power then release button after 10 secs.
Yes 30 secs each cycle is overkill, but allows to be sure.
Aug 11, 2013 | Computers & Internet
My tv is showing invalid format on my ps3 i tried holding down the power button but nothing happen what should i do
You must hold it down for an extended period of time before the video settings will reset, otherwise it isn't a problem with the video settings.
Aug 17, 2011 | Sony Playstation 3 (PS3) Console
My Canon SX120 IS digital camera won't turn on. I used it in the morning, set it down on a table, cam back and it wouldn't work. There is no damage. When I press the power button it does NOTHING. Is there...
If you're after a reset button there might be a little hole you can insert a pin into to reset it, look around the camera.
You should also try holding down the power button for a few seconds, it might have a function where doing that does a restart or something similar. Taking the memory card out and turning it on without it is also worth trying.
Mar 05, 2011 | Canon Cameras
DO YOU FIX PS3s... I have tryed everything i can think of incloding different cables HD & normal,different TVs HD & normal Also holding down the power button and waiting for the beeps.But nothing...
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
SAFE MODE
Have a look at this, it may help.
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
Its not working!
try resetting the video, by holding down the power button till you hear 2 beeps. if no luck call 1 800 345 SONY. Free tech support and free 1 year warranty with all Sony PS3's they will send you a box with pre paid postage to send it to them and fix.
Dec 20, 2008 | Sony Playstation 3 (PS3) Console
OSD
If you have checked thru the owners manual and could not find anything helpful for getting the OSD working again, you may want to try this reset procedure at the end of this post and then try to get the OSD working again. The owners manual should give instructions on how to activate the OSD.
This reset procedure will clear all the setting you have made, so make sure you know how to put those settings back in again before doing this.
If you do see the video from what ever video device you have connected to the unit (DVD player ect. ) but you don't see the OSD when you enter into any setup menu, then this reset procedure may help fix that problem.
If you are not seeing any video from the video device connected to the unit, then you may just have the wrong setting for the output from the video out to the TV. These Denon's are very complicated receivers (which you must know, since you own this receiver), and an improper setting can be causing the problems you have.
Befor eyou do this, go thru the settings menu and look for a OSD setting and see if it is turned off. If so, turn it on. If you can not find anything for the OSD try using the set up on the display of the Denon instead of the remote.
Here is the reset procedure:
With the unit turned off, hold down these two buttons at the same time:
Pure direct + Direct
while holding those buttons down, then press the power button to turn on the unit. Keep holding those buttons down for at least 3 seconds after turing the unit on and the display should flash at about 1 second intervals. then you can let off the two buttons and the unit is reset back to the same settings as when it was new. You now will need to put all of your custom settings back in to the way you need them.
Jul 09, 2008 | Denon AVR-3805 Receiver
PS3 NO VIDEO/AUDIO output- no display NOTHING NEED HELP!!!!!!!!
I have a friend at playstation and when I called I had no video or audio using the AV Multi Out.
The soultion is:
1. Turn Off in back (wait few seconds for it to re-set)
2. Turn on in back
3. Turn on in front and hold your finger on it 'till it turns off again -
(you get the beep on then the three beeps for reset and it will eventually beep again and turn off)
4. Turn off in back (wait few seconds for it to re-set)
5. Turn on in back
6. Turn on in front hold finger for three beeps and damn it works!
I was so Pissed for two days and spent $80.00 on new cables (that I did not need) and the answer was so simple.. The SONY on-line troubleshooting instructions really need to be updated!
Let me know if this works for you!
Thanks
Mike M
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
Ps3 not working
Is there sound? If so, then maybe your video settings got mixed up. Try the video reset.
When the PS3 is in standby mode (red LED lit), hold the Power "button" until it beeps for booting, keep holding until it beeps again (not to turn it off).
If done correctly you should see something again (480p resolution) allowing you to change settings.
I hope this will help you out.
Greetings,
DarkNeogen.
Jan 29, 2008 | Sony PlayStation® 3 (60 GB) Console
Sony PS3 40GB Best Sellers Bundle Console Logo
1,510 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
