Hampton Bay air conditioner wall unit doesn't cool
My Hampton Bay air conditioner wall unit doesn't emit cold air. What can I try to fix it? What's the problem?
  • 1 more comment
  • sandcrazy75 Jun 30, 2009
    I noticed it last month and have turned it on twice since to see if it would cool. It turns on and blows air out fine, but just not cold air
  • Kendall Clendenen
    Kendall Clendenen May 11, 2010
    Many things can cause this. Do you have any details of how and when this happened. Low gas,bad compressor, burnt wires outside unit tripped on pressure or overload. main power may need turned off and back on to reset lockout. out door coil may need washed out.
  • Anonymous Mar 24, 2014
    Hampton Bay A/C wall unit will not blow, it just hums then turns off a minute or so.
  • 8,220 Answers
Might be the CAPACITOR
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 01, 2009
My unit is making a loud noise and is spitting water out with the cool air
i have had units turned too cold and ice forms on coils. shut unit down and take it out of window. turn /tilt and when all water runs out, re install and turn back on to a Higher , less cold setting.
Jul 29, 2012 | Hampton Bay HBLG5004 Air Conditioner
What does the "dry mode" mean in a Hampton Bay air
"dry mode" normally means, to dehumidify only. this will not cool the air nor heat it consistently.
Jun 19, 2011 | Heating & Cooling
The "dry mode" dehumidifies the air. This is useful when you do not need to cool the air but the relative humidity is higher than you want to have inside. You get the advantage of bringing in the fresh air without increasing the indoor humidity.
I hope this helps.
(this applies to all air conditioners with a dry mode)
Jun 19, 2011 | Hampton Bay HBLG5004 Air Conditioner
The air conditioner is emitting cool air instead of cold air. I have the setting on cold and the temperature setting at 60 degrees. On these days that have been near and over 100 degrees, that cool air...
Typical temp split should be 15 to 20 degrees. A 75 degree return air temp should be in the 50s. Be sure coils are clean , if in that range the machine can do no more. If it is not, you likely have a refrigerant issue.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 31, 2017 | LG LWHD1009R Air Conditioner
Not cooling
you may be low on refigerant
Jun 27, 2010 | Hampton Bay HBLG5004 Air Conditioner
I AM TRYING TO FIND A MANUAL TO THE HAMPTON BAY AIR CONDITIONER
THE UNIT AM SPEAKING OF, IS A AMANA AIR CONDITIONER... WHAT I HAVE TO DO IS BUY A THERMOSTAT CONTROLED AIR CONDITIONEER. ANY RECOMENDATIONS... THE SLEEVE THAT THIS UNIT HAS TO BE PUT INTO IS 42 X 16
Dec 03, 2009 | Hampton Bay Heating & Cooling
Air condition unit freezes up
the unit may be too small for the room. or the filter need to be cleaned. also once a rea you need to sprey a mixute of warm water and amonia to clean the coils.
May 16, 2009 | Hampton Bay HBLG5004 Air Conditioner
Remote operation of ceiling fan NOT working.
Try to check the remote control by using camera or cell camera, just use it as your eyes to see if the remote control emits signal. Just point your remote control to the camera and "on" then check if the remote control emits light, if no emitted lights means defective remote but if emit lights then the receiver is defective . Try also to locate if there are any reset or rst button on the remote control and press it then test.
Dec 31, 2008 | Hampton Bay Heating & Cooling
Heating & Cooling Logo
466 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
