Question about Samsung PS42P2S 42 in. Plasma Television
SAMSUNG PLASMA MY SAMSUNG PLASMA KEEPS TURNING ITS SELF ON AND OFF
  • 1 more comment
  • petrakis May 05, 2008
    Randomly my samsung 50 inch plasma , brand new keeps turning itself off and on straight away!
    I had it replaced by the company and the second tv does the same problem, please help sombody?
  • ianandlouise Jul 08, 2008
    just took delivery of new samsung 63inch plasma and it also keeps turning itself off and on, looks like a fault
  • locked_in_cl Feb 06, 2009
    My LCD Samsung with turn off with everything else running fine...no cords are loose or damaged...it turns off and then after a while will turn back on....Don't know what the problem is.
If you are constantly having this problem with every tv you get it is not the tv. ALSO make sure it is random and not when you are using other items because of frequency issues. One more thing is static. I would talk to geeksquad at the store and have them problem solve it in a different environment from your house.
Posted on Jul 14, 2008
  • Samsung Master
  • 5,138 Answers
Take to repair shop this is no fix it your self problem.
Posted on Feb 08, 2008
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
My New Samsung 50" Plasma (PS50C451B2D) keeps
if timer is not activated, your unit needs servicing.
have the power supply check first for output voltages it may not have enough to power up some of the circuits board.
Feb 08, 2011 | Samsung PS50C451B2D 50 in. Plasma TV
Tv keeps turning its self off
most of the time there is the main power capacitor " the biggest one " could cause this problem but some times also there is aleakage in the power transistor of the main power board, you can check them out.
Jan 07, 2011 | Samsung HP-R5072 50 in. Plasma HDTV
Sansung tv keeps turning on and off by self....
A common problem is poor solder connections on the transistors that drive the power relays. QX801 and QX802.
Apr 25, 2010 | Samsung HP-T4264 42 in. Plasma HDTV
Many issues can cause this, there is no simple answer, but one common issue is the convergence circuit failing. The set will need repaired.
If you are handy with electronics you see if the convergence ic's are failing, usaly on these there is a short jumper connector from the right board to the middle board closest to you from the back, if you disconnect this connector from the back and the tv comes on it is a convergence ic problem. In this case you need to replace the ic's on the convergence board the two stk392 ic's plus check the resistor.
Sep 01, 2009 | Hitachi 53UWX10B 53" Rear Projection...
My samsung plasma keeps turning itself on and off
Have you checked to see if it is Shop Mode, if it is you have to turn Shop Mode off.
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Keeps turning off-Philips 50PF9431D
63 inch samsung plasma turn off then back on buy its self
Nov 14, 2007 | Philips 50PF9431D Television
Samsung PS42P2S 42 in. Plasma Television Logo
215 people viewed this question
Jerry Greenberg
Jerry Greenberg
