Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
How do I replace the Projection Bulb on a Sony KDF-E55A20 and what where do I get the replacement bulb the cheapest....I have pulled the module...
  • 668 Answers
It is my recommendation that you replace it with a Sony Lamp Assy. Do not go cheap buying a generic or just the lamp only. They have been known to be unreliable and the wattage to be wrong causing the surrounding plastic to melt. Sony will not be responsible for this if it happens. If you have pulled the Lamp Assy. out, just put the new Lamp Assy
in it's place. Be sure to remount the lamp cover properly. Remount the outer cover and you are good to go.
You can contact Sony at 1800-222-SONY
for the lamp.
Hope this helps,
Skyassoc
Posted on Jul 01, 2009
I it easy to cange the lamp in my e55a20 sony tv. I have one coming 2moro, and was wondering the difficulty level.
It involves removing a housing an pulling out the bulb then inserting the new bulb and replacing the cover. Sony has excellent instructions in the owners manual:
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=KDFE55A20
pg 76
Mar 02, 2011 | Sony KDF-E55A20 55 in. LCD Television
I have a Sony KDF-E55A20. I just replaced the bulb, the old bulb was broken. I replaced the bulb but the TV still does not work. There's a series of 3 blinking red light. What does this mean? After I put...
Put lamp cover back on tv as it will push a safety switch inside then tv will turn On.
Lamp cover is first thing that you removed to replace lamp in tv.
Hope this will help you.
Thanks.
Nov 17, 2010 | Sony KDF-E55A20 55 in. LCD Television
Replace sony projection bulb, tv has delay with picture coming on
I would recommend taking your tv to a tech. You don't want to risk breaking something else in your tv over a simple issue.
May 27, 2010 | Sony KDF-E55A20 55 in. LCD Television
Bulb keeps going on and off . does that mean the bulb is going bad
If TV shuts off and turns On itself again then yes, bulb in TV is weak and need to be replaced.
Please buy Sony oirignal bulb/ lamp for your TV safety.
Lamp/ bulb replacement procedure would be written in user manual.
Thanks.
Jan 01, 2010 | Sony KDF-E55A20 55 in. LCD Television
How can I replace the lamp myself? It is for a Sony KDF-E55-A20 rear projection TV.
Lamp replacement is not so difficult in Sony KDF-E55A20 and its procedure is written in user manual.
You can download free copy of user manual by clicking Sony Support.
Jul 24, 2009 | Sony KDF-E55A20 55 in. LCD Television
Wrong model number listed in my original question
I gave you exact and correct lamp part number of KDF-E55A20 and explained in previous reply that there is no difference between XL-2200 and XL-2200U lamp. both are same, first on came with new TV and second one is its replacement number.
KV-36FV26 is CRT TV and has no lamp inside.
May 18, 2009 | Sony KV-36FV26 TV
Bulb Replacement for Sony TV KDF-42WE655
no you should only replace a bulb with the one made for that brande t.v. you should put in a sony xl-2400 in your sony t.v. and yes you should get both housing and bulb in 1 i bought mine off ebay for about 116.00$ both lamp and housing very easy to replace good luck also if you have a sony kdf-42we655 or 50we655the lamp part # is xl-21oou or xl-2100
Jan 14, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do I get to the bulb?
You can buy Original Lamp for your Sony KDF-E55A20 from Sony Accessories (Official Website of Sony) by entering model number as above in search box.
For your information, Lamp (bulb) part number is ...
A1085447A* LAMP BLOCK ASSY XL-2200U and price is approx $200
Thank you.
Oct 03, 2008 | Sony KDF-E55A20 55 in. LCD Television
Kdf-e55a20
In my experience with these models, if have found that your fault could be due to a blown bulb assembly. This can easily be checked by looking up the bulb replacement procedure in the user manual. The bulb should look clear and see-through to the tip of the filament. There must be a small class pipe inside which has a wire connected to the tip.
Any white residue or black discoloration inside the bulb indicates a blown bulb. You can contact your nearest Sony service centre for a new replacement bulb. Write down the "XL-xxxx " number as you will have much faster result than giving the model number.
If you need any more assistance please post a reply.
Best of luck.
Mar 02, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
89 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
