Question about Roper RT21SKXLQ Top Freezer Refrigerator
Roper Freezer doesn't cool adequately
My Roper Freezer doesn't cool adequately. It couldn't make ice today in the trays (not a cube maker). The refrigerator portion keeps things cold. I've adjusted the freezer settings as low as they go and still no help. Any suggestions would be greatly appreciated!!!!
  • 42 Answers
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Posted on Jul 02, 2009
Ice maker on whirlpool quit working .
If it's like my Samsung, there is a reset micro switch button in front of the box containing the ice cube tray. Press it and the machine resets, the ice cube tray rotates, dumping the cubes. It then rights itself and fills with water. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
Kitchen aid superba
Are they staying on top of the ice maker or are they going all over? The ice bucket might be the wrong size.
Oct 29, 2013 | Roper RT21SKXLQ Top Freezer Refrigerator
Roper Refrigerator. No ice maker. Freezer on top. Water pooling in refrigerator. keep refrigerator in garage.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 20, 2011 | Roper Refrigerators
Freezer is not very cold. Ice maker not working e...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 20, 2010 | Bosch Evolution B20CS50SNB Side by Side...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Freezer side will not keep ice cream, popsicles or orange juice frozen. it will make ice in ice cube trays-the ice maker makes very few ice cubes.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check
, defrost heater, defrost thermostat.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 06, 2009 | Frigidaire FRS6R5EMB Side by Side...
Same problem
i suspect it have a leak the gas level are very low
Jun 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Roper Ice maker wont kick ice cubes out of tray.
Remove white plastic cover on ice maker. On bottom you will notice the heater connections, check for voltage. If good, heater is most likely bad.
Apr 16, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Ice Maker Stopped Making Ice & Cubes are Melting (rest of freezer is cold)
can you pull the cover off the ice maker to see if the gears are bad?let me know more-mike
Oct 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Roper RT21SKXLQ Top Freezer Refrigerator Logo
197 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
