Question about Whirlpool ED2FHEXN Side by Side Refrigerator
My whirlpool refrigerator side by side is hot between the refrigerator and freezer?
  • timmclaughli Jun 30, 2009
    It is not just warm, but hot and burn to the touch. This isn't normal, what can I do?
  • 40 Answers
In some sidebyside appliances there is a heater in the middle to prevent condensation.
Posted on Jun 30, 2009
  • quellen1980 Jul 01, 2009
    Basicly it depends to runtime of the appliance when it runs more it heats more.it also depends to the ambient temperature and the warm food which you put increase the load.If possible check the user manual sometime these heaters can be manually deactivated.but be sure that your kitchen humidty is not so high otherwise you face with condensation
The outside center and out side corners are very hot. Everything else is working fine
Hot refrigerator I have a Samsung refrigerator RS2630SH ...
www.fixya.com/support/t322304-hot_refrigerator
Also the freezer side outside wall is very hot to touch. Ice maker does not work as well. Any suggestions appreciated, excluding the one "not to buy Samsung ...
Samsung RS2630WW Side by Side Refrigerator Divider hot ...
www.fixya.com > ... > Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator, divider hot related issues. ...Compressor/motor on mu Whirlpool frige is really hot. face of fridge/freezer ... centerdivider is hot to the touch, it means that the compressor is running hot. either your ...means there is inadequate air flow over the condenser coils outside the unit.
[PDF]SAM0059 Samsung Side-by-Side Refrigerator.pdf
applianceassistant.com/.../sam0059_samsung_side-by-side_refrigerator.p...
A newly developed SAMSUNG side by side refrigerator in 2004 has the .... Warranty service can only be performed by a SAMSUNG authorized service center. .... SUB-CONDENSER. Hot Pipe. Hot Pipe. Compressor. SIDE CLUSTER PIPE .... corner of the refrigerator. ... The CoolSelect ZoneTM thermistor is located outside.
Jan 25, 2016 | Samsung RS2556 Side by Side Refrigerator
Refrigerator/freezer
sounds like gas has leaked from the refrigerators sealed pipe system. this is not something you can repair at home.
Nov 10, 2013 | Whirlpool Refrigerators
My whirlpool is over heating its a side by side, the piece tht divides freezer from fridge is very hot
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Aug 26, 2011 | Whirlpool GS5SHAXN Side by Side...
Why wouldthe center piece between freezer & refrigerator get hot
There is a heater located behind that strip known as the mullion heater.
Look to see if you have a switch labeled "anti-sweat"
Apr 05, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
TURN OFF FREEZER HALF TO DEFROST WATER LINE THAT FEED ICE MAKER
Just turn the refrigerator off inside on control panel. Then get a hair dryer and melt the ice away from the tube taking care not to get plastic too hot. Sea Breeze
May 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side, blowing hot air on both sides
First, you must determine if the compressor is running. The compressor is located at the bottom of the unit in the rear. Feel for motor heat and slight vibration. If it is cool then the problem may be an inexpensive start relay. If the compressor is very hot, the start relay could also be the problem or the motor has seized. Find the wiring diagram in the rear of the unit to replace this relay which should be availible at your local refrigeration supplie house.
Ray
Jan 05, 2009 | Whirlpool Refrigerators
Front metal piece that the seal goes against - between freezer and fridge
ED5VHGXMQ10 Whirlpool Fridge
I have the same problem. Too hot to touch between the freezer and refrigerator door. Is
this normal?
Jul 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
218 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
