Question about Kensington Electronics - Others
Error reading/writing on pen drive
I have a kingston 8gb pen drive which i plugged in my computer and added some folders to it, thenafter formatting the computer. Now when i plug the pen drive back in the computer i see the root folders in it, but when i open the root folders i see nothing but alot of folders, named as ********. Now i am not able to open these folders nor am i able to copy it. Whenever tried to copy it, it says '' Error reading data from Source file or Disk ''. I need this Pen Drive to be recovered ......
Can somebody please help me ...
  • Kensington Master
  • 27,725 Answers
You have to be the computers Administrator to change any values on any Hard Drive on your computer. Click start control panel user accounts on the users tab click the name of the computer administrator you must have full control. Click start click to open on my computer you should see your drive could be C: , or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select open
Right click the icon of your drive (It should be C:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
Posted on Mar 01, 2013
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: my Pen drive is KINGSTON DTI/8GB. And not geting
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Posted on Oct 23, 2009
I install Universal-USB-Installer-1.7.9.3 related to ubuntu in Kingstone 8GB pendrive. Now the pen drive is not working properly.When i try to format it .itsays it is write protected. How can i format it?
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
or
use any low level formatting software....
Sep 11, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My kingston 8gb and 4gb pendrive when connect to my computer massage appear "disk is write protected" how to solve describe me with full detail
If your pc has virus or your pen drive have some virus u get these problems just try to plug in another pc and try to format..
Aug 20, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have one 32GB Kingstone Pendrive & I have store on a data of above 1 gb but When It reconnect to PC it's show the only empty folder, so please send me solution of the same...
It’s difficult to give you an exact fix without having your pen drive in hand and at a computer, but I will give you some things to check for:
1) Does the pen drive have a read – write protection enabled? If so turn it off.
2) Make sure your windows explore has the folder view options set so that you cans see file extensions. This will definitely come in to play if the files on your pen drive are not common files. e.g. (ms word)
3) No the bad news!!! There are many reports of the 32GB Kingstone pen drive being FAKE. If you do a google search you will see many consumer complaints.
Respectfully,
David
fix4mypc
Aug 07, 2010 | Computers & Internet
USB FLASH WRITE PROTECT ERROR
CHeck USB for any write protection Notch. If not then check your computer setup, not to mark USB as read only.
Jan 27, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My 1gb kingston pen drive is write protected
Try to right click your pen drive then copy and paste it on your My Documents folder. When done, follow these steps:
1. Go to start menu
2. Click Run and type cmd
==A command prompt shows.==
3. Type cd\
4. Type format x:
5. Press Enter key
6. When done type exit
Note: Copy all the files you have transferred on your My Documents folder and paste files again to your pen drive. You can now do whatever you want on your pen drive.
Dec 25, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Write protection
Get this program:
http://www.4shared.com/file/72797673/93a74bfa/UsbWriteProtect.html
You might need to get winrar from http://www.rarlab.com/
to open the rar file.
Extract all the files to a new folder, run the exe file and click the or disable Radio button and close the program.
Now remove the pen drive and plug it back in to the USB slot, Now open my computer and try to create a new folder in the pen drive, you can't. You get an error. That's what you wanted right? :-)
HTH,
Deboo
Dec 13, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Problem in kingston 8gb pen drive please help me out
some times i am un able to copy to my pendrive. the message im gettin is I/O error
Oct 09, 2008 | Computers & Internet
Electronics - Others Logo
103 people viewed this question
Top Kensington Electronics - Others Experts
Marvin
Marvin
Are you a Kensington Electronics - Other Expert? Answer questions, earn points and help others
