Question about Car Audio & Video
94 chevy blazer radio wont work?
My radio shows the time but wont turn on? Please someone help me i cant take not having music when i drive:) lol Please any suggestions are welcome.its the factory radio.
thank you
    President:
  • 1,114 Answers
There are two fuses to check. One is for the clock and one is for key on or "IGN" power (ignition) If you don't have your owners manual, when you pull the fuse box cover, all the fuses are listed. You may have as many as three fuse panels. One under the hood, one under the steering column and one at the floorboard or either kick panel. (by your left foot) Even possibly on the left side of the dash that you see when you open the door, or the same on the right. It varies from trim level to trim level on GM's. Hope this helps
Posted on Jun 30, 2009
Will a 1994 - 2001 auto transmission fit a 1999 chevy blazer
nope wont work big difference 94 OBD 1 type and 1999 OBD 2 type transmission.electronics differents.
Apr 08, 2013 | 1994 Chevrolet S-10 Blazer
I have a 94 s10 blazer 4.3 and I had to remove the distributor but never marked it so now the timing is messed up. The distributor dose not have a #6 alignment mark so I cant get it working right. How do I...
Remove cylinder # 1 spark plug, # 1 is the front one on drives side, turn crankshaft pulley to TDC on compression stroke, you'll feel the comperssion at cylinder #1 spark plug hole, follow cylinder # 1 spark plug wire to distributor cap, mark outer part of distributor where # 1 sits, remove distributor and restabe distributor with rotor at mark you made, then set timing.
Jan 22, 2010 | 1994 Chevrolet S-10 Blazer
Cant use the USB! Says Close! nthing happens!
check the owners manual for the stereo and see what file system format you need to use on the flash drive i know i had the same problem when i changed radios worked on my old one but plugged into the new stereo wouldnt load had to unload the music and reformat the flash drive and then reload the music onto it that took care of the problem. where you have tried two different usb drives would say not likely you have bad drives
May 19, 2009 | Power Acoustik PTID-4003TV Car Video...
94 chevy k5 blazer works fine cold problem is that when it worms up it stalls backfires into the exauhst and losses power and turns off
Most of the time if it was a fuel pump it wouldnt start at all.Sounds like a tps problem.If there is a check engine light on, it would probably be cheaper to pay someone to scan it, instead of guessing and buying
sensor after sensor.Some of them are quite expensive.
Hope i was of some help
May 14, 2009 | 1994 Chevrolet K1500
94 s10 blazer wont go out of four wheel drive
The electric shift solennoid on the transfer case is probably bad,common problem with these.
Dec 25, 2008 | 1999 Chevrolet Blazer
I cant sync music to my sons psp!
Lol You're kidding right ?!? You've got to COPY & PASTE in order to add music to the psp .
Dec 05, 2008 | Sony PlayStation Portable (PSP) Console
Turn signal relay switch, 94 s10 chevy blazer
The Turn signal relay on a 94 s10 blazer is located under the cluster area right behind the panel that holds the parking brake release handle you will see it once a couple of trim panels get remove it will be to the right side of the brake release handle
Nov 18, 2008 | 1994 Chevrolet S-10 Blazer
1996 chevy blazer radio turns on but there is no sound
I have a strong feeling that the head unit "radio" has finally gone bad. You describe a situation, in which you have to turn it on and off, to get it to work. Typically if the sound comes out of all speakers, after doing that, then the speakers were never broken. The head unit itself should be replaced. I hope this helps.
Nov 16, 2008 | 1996 Chevrolet Blazer
Car Audio & Video Logo
135 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
